Put a dab of dielectric grease on the bottom of light bulbs.
   / Put a dab of dielectric grease on the bottom of light bulbs. #51
Don't take our word for it, take off the plastic and take your pocket knife, and scrape it, and you will see the copper.
Oh I totally believe everyone. Never investigated, just assumed they were aluminum. :)
   / Put a dab of dielectric grease on the bottom of light bulbs. #52
I used to use petroleum jelly or dielectric grease on battery terminals to eliminate corrosion. Lately I have not been and don't see any corrosion, I assume due to the much better sealing of the batteries. I just replaced the 6-1/2 year old battery in my John Deere (which was actually vented but routed away from the battery) and had no corrosion on the terminals. The terminals had never been disconnected since installed at the factory.
I know I need to get more consistent on using grease on my trailer connections though.
   / Put a dab of dielectric grease on the bottom of light bulbs. #53
Am I the only one who doesn't have troubles removing light bulbs? But then I don't tighten then with a pipe wrench :D
   / Put a dab of dielectric grease on the bottom of light bulbs. #54
Angels watching over the innocent?
   / Put a dab of dielectric grease on the bottom of light bulbs. #55
No, I don't have any trouble removing light bulbs either. I use my index finger and thumb to gently tighten them. I don't use any grease on the light bulb bases either. The only one I had trouble removing was a clearance light on a 100 foot radio tower. It was struck by lightning. When I got the glass globe off and looked for the bulb, I had a little trouble finding it. It was vaporized. What was left of the base was still in there but the glass bulb was now a thin film of silica on the inside of the glass outer globe. I managed to get the base out with the aid of pliers and the new bulb installed, but it was a pain.
I don't have any trouble with someone putting dielectric grease on the bulb threads and contacts, but I haven't needed to do that. I would certainly consider it in an outdoor or wet location. I have certainly used it on automotive bulbs. In fact I think a lot of them come that way from the factory.
   / Put a dab of dielectric grease on the bottom of light bulbs. #56
No, I don't have any trouble removing light bulbs either. I use my index finger and thumb to gently tighten them. I don't use any grease on the light bulb bases either. The only one I had trouble removing was a clearance light on a 100 foot radio tower. It was struck by lightning. When I got the glass globe off and looked for the bulb, I had a little trouble finding it. It was vaporized. What was left of the base was still in there but the glass bulb was now a thing film of silica on the inside of the glass out globe. I managed to get the base out with the aid of pliers and the new bulb installed, but it was a pain.
Okay, we'll give you that one. :laughing:
Agreed! I use it on all automotive connections EXCEPT the battery terminals. I use a spray-on protector there, because it doesn't make a mess. If I DID use grease there, I would apply it AFTER tightening down the connections.
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
