JimRB
A friend at work said their water bill has been out of the norm for more than a few months. Her husband is not inclined to fix or do anything around the house. The water department guy came over and listened for leaks but could not hear anything. Pipe touching faucets and toilets to hear leaks. Kind of like using a stethascope.
So how do you find a leak of maybe 6-10 gallons an hour when there is no sign of wet spots outside the 1,000-1,500 sf slab house?
I see no clues in the garage where the water heater is set.
I do not see where the water service enters the house. I used to see pressure regulators in the houses I worked on 25 years ago as a tile guy. I also saw main cut offs inside the house. Granted the houses I worked around 25 years ago were "higher end" houses, one might hope a starter house might have a service entrance cut off. Then again it is only 40 feet from the house to the water meter. Where I was going was if there was a cut off inside the house I could turn that off to see if it is the water line feeding the house. Yard is also messy around the house so I can't see anything. It might take an hour to move junk and run an old fashion rake.
I think it is PEX plumbing. I haven't been around houses that do PEX, or I have not paid attention. I haven't done home construction in 20 years. Do they all use distribution manifolds or do they often plumb the way I have done copper or PVC?
This is now a curiousity question more than anything else. They need to get a plumber out that is experienced with how things are done in that neighborhood.
