Burn Barrel design
   / Burn Barrel design #51
UPDATE: Having read all of the replies (and not possessing a rifle/shotgun) I decided to try out the 'vortex' design. Seeing as I have a 5" counter-rotating saw I used it to cut a large 'X' in the bottom to provide drainage/air-intake... the saw was like a hot knife through butter! :thumbsup: A pair of flat-nose pliers easily put a slight 'downward' bend to assist drainage.
I then cut two, opposite facing, rectangles on the lower portion. One of them large enough for a shovel. Seeing as the barrel is 6' in diameter, I marked and cut 3 vertical lines half way up at 2' intervals. I used a crowbar to open up the cuts to form the vents... thankfully I remembered to form my vents all in the same direction. :dance1:
I did run a flat file over all of the cut edges just to remove any burrs. If I didn't, then that 'one' would surely cut my clothes or me later on. I finally walked a magnet over the work-area to get all on the metal shavings & such (which would've surely found their way into some tyre or boot sole).
That is the Cadillac of burn barrels. What a beauty with ideas I plan to steal. :D
   / Burn Barrel design #52
Wagtail, is your area prone to grass/forest fires? I ask because of all of the precautions you mention taking when you are about to burn. If you are close to town I could see it to. My last house I was close to town and I got the fire department called on me a lot... not that I called them mind you :laughing:
Our precautions as a kid were "Hey go burn trash"! I was the trash burner designee usually. I always loved after Christmas I got to burn BOXES !!
If I had to call the fire department every time I can only imagine how that would have been
   / Burn Barrel design #53
Looks like a real inferno there Wagtail. :thumbsup:
   / Burn Barrel design #54
Nice - very little smoke suggesting a very clean burn.
Mate, practically everywhere in Australia is prone to bush fires (grass/forest or brush fires, as you may know them). All it takes is one 'whiff' of smoke and your average Aussie is looking around for the source! Plus, we're calling in to the Fire Brigade to report it, so giving a ring to the Brigade prior to burning means that they won't be running around like a blue-arsed fly looking for a fire. Outside of a metropolitan area, the Fire Brigades are all volunteer.
The 'burn permit' is free, as is the call. If you don't get the 'permit' and the Brigade and Tassie Police attend your property, you will be fined. Most of Aus is forested with eucalyptus varieties and pine plantations. My property is practically all Blackwood.
Mind you, as the regions in the State dry out during the Summer or during a drought, then a 'serious' permit or outright ban is put in place. Including 'campfires'.
Oh, and the 'permit' is not a piece of paper, so you don't have to wait to receive it. It's just a phone call to say you're going to burn... Mostly they'll say "Right-O, where are you burning and thanks for calling."
Ta, James. As I mentioned, if I hadn't been wearing protective clothing I would've been in some strife!
The anti-flash hood and gloves was needed.
   / Burn Barrel design #58
I wondered if that might be the case. That makes sense. I guess it would have to be that way if there was that much risk of a bush fire. I have a feeling it is that way in some of our Western states. It gets the way here sometimes during very dry summers. We are not allowed to set off fireworks etc. and they put out no burn warnings.
But that was truly amzaing how high those flames went.. no burn barrell shot up with a .22 ever created a plume like that.
   / Burn Barrel design #59
That paints a mental picture that I am having a hard time getting out of my head. :laughing:
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
(APPROX. 12) UNUSED FUTURE 4' X 8' PLASTIC MATS (A52706)
(APPROX. 12)...
2024 Sky Jack SJ45 AJT Man Lift (A54865)
2024 Sky Jack SJ45...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
