Burning Brush
   / Burning Brush #121
My method is half of a bale of junk hay spread around the pile, then I pour used motor oil on the hay (about 1 gallon/pile). That way the oil never hits the ground, the hay acts as a wick and the pile starts every time.
Aaron Z
   / Burning Brush #122
I use a little diesel (in the red gas can, labeled diesel) on the down wind (less than 10 mph) side, so it doesn't burn too fast.
   / Burning Brush #123
I save all my plastic and burnable garbage for this purpose. Stays lit longer then fuel.
   / Burning Brush #124
Lumberjacks in the area tend to use a couple of old tires that they light up with dirty fuel. Tires never go out and will burn hot enough to ignite even the wettest green slash.
Gets a but smoky however.
   / Burning Brush #125
The noxious smoke from burning tires is why burning them (even as a fire starter) is outlawed in most places now.
   / Burning Brush #126
Oh I know that, but loggers back in the bush tend to overlook that.
And actually birch bark (and other resins) probably smokes about as much as a tire or two in the long haul, besides 20-30 miles or more from nearest habitation kinda makes then a bit more daring.
   / Burning Brush #127
One can look at a 'finished' burn pile and learn a lot about the burner. I am one that constantly 'cleans' up and pushes the fire together trying to burn everything 100%. I also almost always use the same spot for my brush pile... big or small so every thing burns up eventually. One thing I don't do but I probably should is extract the metal nails, brackets, etc. that get left. I also tidy up around the burn spot so there isn't grass, branches, etc. that could help spread the fire. Just part of enjoying the ritual for me.
Mark, Kitsap County ordinance states natural wood only, no building material or treated wood. I always sneak in some old pallets and stuff though, even a hunk of RR tie now and then. Source of one of my flat tires later. now that teh rains have everything soaked around time to get going on my current four "10' " piles.
Ron
   / Burning Brush #128
Ron
10ft piles???
Oh Yeah Ron, I do cheat a little too. Larger than 3ft by 3ft pile, miscellaneous scraps from the shop, etc. I am in pretty good shape now... Probably no burning until spring! Got some good burns in right after the ban was lifted and weather still pleasant.
   / Burning Brush #129
Yeah piles 4' - 10' a require a short term permit. I get a 4' permit at the beginning of every year. I pile as high as I can w/the BX. After setting a while they compress down and I add more. Use a propane burner and a leaf blower and it is roaring in no time even when soaked with rain. I have a 38 GL Propane tank off a motor home that I use, so never have the frosting and low pressure problem like the small tanks. I have it mounted on a square tube skid for handling. My BX can just lift the tank when full.
Ron
   / Burning Brush #130
I start mine with a weed burner as mentioned previously. It's the only way to fly.
I pile during the year and wait for the county to lift the burn ban and light up the very next weekend. I keep the actual burn pile size w/in regs but stack more on with the grapple as fast as the fire can consume it and keep a HOT, fast fire. Did I say forget to mention a HOT fire? The fire needs to be HOT. I drop my piles at the edge and push in with the pile as a buffer because the fire is HOT. I can't get near it, because it is too HOT.
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
28013 (A50322)
28013 (A50322)
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
