Oil Change - Spring or Fall?
   / Oil Change - Spring or Fall? #12
Also spring and fall normal use,plus I mark on filter/filters month change.
   / Oil Change - Spring or Fall? #13
good idea, been doing that lately. (along w/maintenance log) i usually go by hrs, not calendar... so on black filters (on most of my mowers, etc) how do you mark? on white duct? just asking :)
   / Oil Change - Spring or Fall? #14
Fall - after you have ran it awhile. Why let it sit with old oil in the motor. Ready for spring with new oil ready to go.
   / Oil Change - Spring or Fall? #15
knife on a black filter shows up and stays for the life of filter.
   / Oil Change - Spring or Fall? #17
fall...less busy with mowing. have heat in shop
   / Oil Change - Spring or Fall? #18
I use a label maker with date and hours. White tape with black letters.
   / Oil Change - Spring or Fall? #19
Silver sharpie or white paint marker. Masking tape also works.
   / Oil Change - Spring or Fall? #20
I am a fall oil changer, unless it needs being done sooner due to hours. I do use my tractor all year though.
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
