Just about to buy a Branson 4720 hydro Hydro
   / Just about to buy a Branson 4720 hydro Hydro
Thank you for the little tip.
so far i love the thing only thing that is annoying i got a 6ft brush hog type mower that i keep shearing the bolt on the drive line going though heavy brush. was hoping to be able to cut a little heavier stuff.
   / Just about to buy a Branson 4720 hydro Hydro #12
Keep the rpms up on that engine for dpf reasons. This engine likes to run at 1800rpm or more. Other than that have fun with it and enjoy.
Since the torque curves on my 2 Cummins licensed Bransons peak at 1600, running at 1800, unless low speed is required for a reason is the right choice for a minimum speed. Being above the peak means that when you load the tractor the torque increases as the rpms attempt to fall, balancing out the effect the load has on the engine.
If you do any work below the peak, when you load the engine both torque and rpm fall off and if you over do it it will crater and shut down......to be avoided at all costs to prevent potential major damage to (babbit coated) connecting rod and possibly main bearing inserts.
   / Just about to buy a Branson 4720 hydro Hydro #13
PTO rpm, slow ground speed, only cut half width, Grade 2 bolt, locking nut and leave it loose where it can rattle.
ok thank you ive been tightening the the bolt down ill try the advise
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2018 Vermeer Chipper (A51573)
2018 Vermeer...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
BESTWAY AG LOT NUMBER 53 (A53084)
BESTWAY AG LOT...
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
