Just about to buy a Branson 4720 hydro Hydro
   / Just about to buy a Branson 4720 hydro Hydro
Thank you for the little tip.
so far i love the thing only thing that is annoying i got a 6ft brush hog type mower that i keep shearing the bolt on the drive line going though heavy brush. was hoping to be able to cut a little heavier stuff.
   / Just about to buy a Branson 4720 hydro Hydro #12
Keep the rpms up on that engine for dpf reasons. This engine likes to run at 1800rpm or more. Other than that have fun with it and enjoy.
Since the torque curves on my 2 Cummins licensed Bransons peak at 1600, running at 1800, unless low speed is required for a reason is the right choice for a minimum speed. Being above the peak means that when you load the tractor the torque increases as the rpms attempt to fall, balancing out the effect the load has on the engine.
If you do any work below the peak, when you load the engine both torque and rpm fall off and if you over do it it will crater and shut down......to be avoided at all costs to prevent potential major damage to (babbit coated) connecting rod and possibly main bearing inserts.
   / Just about to buy a Branson 4720 hydro Hydro #13
PTO rpm, slow ground speed, only cut half width, Grade 2 bolt, locking nut and leave it loose where it can rattle.
ok thank you ive been tightening the the bolt down ill try the advise
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
