Oil & Fuel Fuel transfer pump
   / Fuel transfer pump #1
Bass
Kubota GL3710HST
Back problem keeps me from lifting 5 gal can to top of L3710 to pour fuel into tank. Any suggestions on fueling from a 5 gal can would be appreciated.
   / Fuel transfer pump #3
I have sinned.
I'm normally a stickler for safety and doing things right, but I am cheating on my fuel setup. I bought a transfer pump from Harbor Freight, and some fuel-rated hose, and I'm good to go. It's got a thermal overload that shuts off the pump after about 20 minutes. A half hour of cool-down, and it's ready to go again. I've been using it for about 5 months.
12 Volt Marine Utility Water Pump
   / Fuel transfer pump #4
The very reason I bought this 5 years ago. It is diesel rated. Just need to be mindful of keeping it clean. It requires 1.5" opening.
   / Fuel transfer pump #5
Bass
If you do a search, or look at the above replies, you'll see that some use anything from a 2 gallon garden watering can, some 2 1/2 gallon plastic used oil jugs, to 12 volt pumps (from $40 to $300). There are a lot of possibilities.
   / Fuel transfer pump #6
Lots of cheaper alternatives that may not be rated for flammable liquids.
I opted for the more expensive but surely safer steel (or you could get aluminum) 100 gallon tank with a 12 volt (also available in 110 volt) Filrite brand 15 GPM pump with 10 micron inline filter and an auto-shutoff nozzle attached with 25 feet of hose. I got the whole setup used for $350. I bolted some steel swivel caster wheels to the tanks mounting tabs (it is designed to be bolted down to a truck bed) so I can roll it around as needed. Even with 100 gallons of fuel, it can be rolled easily on my concrete shop floor.
I keep it inside away from direct sunlight which limits the condensation factor. It has been a possible lifesaver or at least a back saver for me. I just pull up my tractors or RTV to the shop door, remove the nozzle, turn on the pump and fuel up. Rather than try to hook up cables to a battery, I bought a small automotive battery, put on a battery minder and mounted it above the fuel tank on a shelf. It has been that way for over 5 years and still no issues with the battery.
I opted for the 12 volt pump rather than look for a 110 volt just for the option of having fuel available even if a power outage occurs.
Putting money into a large storage tank and a fairly expensive pump with battery might seem overkill, but just one slip while trying to stand on a tire or slippery tractor platform with a 5 gallon can of fuel could put you in an accident situation that may cost you many thousands of dollars plus the pain and suffering that goes with it.
   / Fuel transfer pump #8
Looks like a nice setup. Let us know how it works out.
2011 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2011 Volvo Semi...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
Bobcat 709 Skidloader Backhoe Attachment (A50774)
Bobcat 709...
2012 Ford Explorer (A50120)
2012 Ford Explorer...
