Hydraulic ramp lifts
   / Hydraulic ramp lifts #1
powerscol
SW Colorado
CT 235
I have a PJ 20+3 deck over with the oversize tip up ramps, PJ Trailers Heavy Duty Ramps . Has anyone added a hydraulic set up to lift them? I'm getting old and find lifting the ramps at times to be problematic. I was thinking of a long cylinder and lifting bracket L shape tied to the gate end with a chain. Locking angle would stay as is. That way if the gates are slid in towards the center it would still work. I looked into adding another spring, but it would make the ends too light - lift on their own. The initial lift is not the problem, it at the 1/2 position things get heavy (overhead pushing with arms). Pictures or drawings would be great. Thanks
   / Hydraulic ramp lifts #2
Are your ramps spring assisted?
   / Hydraulic ramp lifts #3
We made a set of ramp aids out of some Garage Door Springs and some PVC pipe to house it.
Made it to where you could lift them with a single finger.
   / Hydraulic ramp lifts #4
I have built hydraulic ramps for large equipment trailers but not for smaller stuff, Like the others have said a spring assist system is simple to build and works. CJ
Pictures?
   / Hydraulic ramp lifts #7
No, sold that trailer bit Google "garage door spring trailer ramps"
   / Hydraulic ramp lifts #8
What about using a small electric winch to assist? Jon
You know I have always wanted on for the trailer. Long remote cable and a chain between the ramps would work great. :thumbsup: Expensive fix, but could be worth it. What a good brand of winch these days. :D
   / Hydraulic ramp lifts #10
A winch on a trailer is a wonderful thing.
I have a 9500Lb. Superwinch on my 20' equipment trailer.
I am an old guy, and I agree: lifting the ramps is getting tough, even with the helper springs.
I don't see how a winch could work though, unless the trailer was empty.
A loaded trailer would have the on deck equipment blocking the run of the cable.
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
2017 KUBOTA SVL75-2 SKID STEER (A52707)
2017 KUBOTA...
2017 Kubota M7-151 Premium MFWD Tractor (A55314)
2017 Kubota M7-151...
1999 Tropi-Cal Class A Motorhome (A55853)
1999 Tropi-Cal...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
