Hydraulic ramp lifts
   / Hydraulic ramp lifts #1
powerscol
SW Colorado
CT 235
I have a PJ 20+3 deck over with the oversize tip up ramps, PJ Trailers Heavy Duty Ramps . Has anyone added a hydraulic set up to lift them? I'm getting old and find lifting the ramps at times to be problematic. I was thinking of a long cylinder and lifting bracket L shape tied to the gate end with a chain. Locking angle would stay as is. That way if the gates are slid in towards the center it would still work. I looked into adding another spring, but it would make the ends too light - lift on their own. The initial lift is not the problem, it at the 1/2 position things get heavy (overhead pushing with arms). Pictures or drawings would be great. Thanks
   / Hydraulic ramp lifts #2
Are your ramps spring assisted?
   / Hydraulic ramp lifts #3
We made a set of ramp aids out of some Garage Door Springs and some PVC pipe to house it.
Made it to where you could lift them with a single finger.
   / Hydraulic ramp lifts #4
I have built hydraulic ramps for large equipment trailers but not for smaller stuff, Like the others have said a spring assist system is simple to build and works. CJ
Pictures?
   / Hydraulic ramp lifts #7
No, sold that trailer bit Google "garage door spring trailer ramps"
   / Hydraulic ramp lifts #8
What about using a small electric winch to assist? Jon
You know I have always wanted on for the trailer. Long remote cable and a chain between the ramps would work great. :thumbsup: Expensive fix, but could be worth it. What a good brand of winch these days. :D
   / Hydraulic ramp lifts #10
A winch on a trailer is a wonderful thing.
I have a 9500Lb. Superwinch on my 20' equipment trailer.
I am an old guy, and I agree: lifting the ramps is getting tough, even with the helper springs.
I don't see how a winch could work though, unless the trailer was empty.
A loaded trailer would have the on deck equipment blocking the run of the cable.
1263 (A50490)
1263 (A50490)
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
TMA (A49461)
TMA (A49461)
