ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
If you get the OEM remote with the float function, there is no reason to have the slot in the clevis. You would then have a redundant feature. And I believe that the valve with the float function is less $$ than the self canceling valve. Plus you can then have the pin hole up closer to the closed end of the clevis and you loose nothing by using the 8" stroke cylinder.![]()
Hmmm,,, I gotta think about that one. If running my brush cutter and carrying the front of it with the 3pt I wouldn't be able to run the tilt cylinder in float. So if the right side of the cutter hit high ground it wouldn't be able to ride up over it.
Yeah, I definitely want the FD valve. My tractor currently has an SCD valve and a FD valve. My SCD valve works great for running ground engagement equipment like a wheel disc or field cultivator. Everything else I do with the FD valve.
