Hydraulic Top Link "Homemade"
   / Hydraulic Top Link "Homemade" #32
I use the Surplus Center 9-7682-11 for Cat. 1 3/4" pins and comes with BSPPM to 3/8" NPTM adapters and lock valve for cylinder drifting. Easy bolt on that gives a range of ~ 21" - 32". I need the 32" extended length. Make sure the port connection box is turned 90 degrees either way from the photo as no matter which direction the box is located (top or bottom), the fitting may hit something and bend that top assembly. Did it myself.
2X11X1.18 CAT I HYD DA TOP LINK CYL
They also have a shorter OAL one: 2X8.25X1.18 CAT I HYD DA TOP LINK CYL
Good stuff sdef. Thanks for adding the info and the link!!!! :)
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
24in pin on excavator tooth bucket (A56436)
24in pin on...
GMC 2500HD 4wd Service Truck (A56436)
GMC 2500HD 4wd...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Zero Turn Mower (A59231)
Zero Turn Mower...
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A59575)
2006 MAC TRI AXLE...
