Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,181
Chains go on my tractor if there is ice beneath the snow. Otherwise, bare R4 tires.
Also, chains if I head for the woods to buck through snow or if an ice layer below the snow.
Once without chains, I started spinning going up my 12% slope and it was no fun sliding backward and out of any control.. fortunately didn't go over the bank and just did a 180 and into a snow bank.
Have had good luck a few winters just putting the chains on the front wheels.
My rear tire chains fit the tires, so I do not need bungie straps on the sides to hold them tight.
   / Pictures of your snow weapons #3,182
You guys are not into any fun. Put it in road gear and let her spin and slide and see if you can control it. Just pushing is way to boring!
You won't ever see my tractor on YouTube titled Tractor Fail lol
Too dang expensive to fix
   / Pictures of your snow weapons #3,183
Well got the right tire filled in. Will probably modify it next year with a proper splice kit with the studied cross links. I had to run to TSC to get som clips - unfortunate experience as he tried to charge me more than was marked on the shelf. Young kid at the counter tried to say price changed, but I mentioned they then needed to change the sign on the shelf and that is what I expected to pay. Folks were starting to pile up at the counter and he finally called a manager that set him straight and apologized to me. This has happened before, so I will be watching a lot closer there as they ring my stuff up. We could get up to 6" tomorrow, so might get a chance to try everything out.
   / Pictures of your snow weapons #3,184
Hey guys, new to the thread but have been checking out pics in it for awhile. Here's my new tractor and snow set up. I am considering chains after slow sliding into the ditch by the road the other day. I managed to get out but I almost had to get the truck to pull it out.
   / Pictures of your snow weapons #3,185
That is an excellent fit - what is your trick for install and snugging them up. I wanted to run mine that high for clearance, but they walked around to much - thus the spring tensioners - I have the same R4's I have better luck with the front as I can lift the tire off of the ground with the loader. Then I clip the inside S-hook and tighten everything from the bottom position as that is where all the slack ends up.
   / Pictures of your snow weapons #3,186
Nice set up. Looks like you have all the required attachments too, except for the backhoe. Chains will make a world of difference and for you size tires not that much to buy. Lots of types out there and you will probably not need the aggressive ones that I have. Quality Chain and Tire Chain.com have a lot of selections, but shop around as you local Kubota dealer or ATV dealer may have better pricing.
One trick I can suggest from you picture. Use you top link and rotate the box slightly upward, so the back blade contacts the ground first. I set mine for 1/4 inch high in front. This will keep you from gouging the gravel or grass along your drive. Hope this helps
   / Pictures of your snow weapons #3,187
Here is my JD 1020 retrofitted with an old Meyer plow I bought off Craig's List. This represents a total of $250 between the weld shop and the plow itself. It has worked perfectly so far. I may install quick connects at the front bucket to gain right and left but for now the pin will work just fine.
   / Pictures of your snow weapons #3,188
Yeah I didn't need a backhoe on my property. It's about 1 foot of soil and then solid rock over the entire 5 acres more or less.
Thanks I'll check for some chains and I'll give your suggestion re the box blade a shot. My one concern about the chains is my garage floor...
   / Pictures of your snow weapons #3,189
Idk if that's a good or a bad thing, I guess you won't have to worry about stuff settling lol.
   / Pictures of your snow weapons #3,190
Yeah I didn't need a backhoe on my property. It's about 1 foot of soil and then solid rock over the entire 5 acres more or less. Thanks I'll check for some chains and I'll give your suggestion re the box blade a shot. My one concern about the chains is my garage floor...
I have chains on my rears and because I'm a little **** about scratching and getting oil on my house garage floor, I put a couple of cheap sheets of mdf plywood on the floor so the chains, fuel or hydro fluid have never been an issue.
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
2003 Big Tex 10PI...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A55852)
2012 Ford F-450...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
