Tire grooving with my chainsaw
   / Tire grooving with my chainsaw #41
You're absolutely right. I have a hill behind the shop that my New Holland can't make it up, even just pulling itself. Since the chainsaw method was so fast, I should have done a before and after video. The half hour would have limited the amount of change in conditions. I, however, didn't think of it at the time.
Oh, man what a unfortunate lost opportunity to settle this enquiry once and for all.. enquiring minds want to know. :D
   / Tire grooving with my chainsaw #42
yea, its almost as important to us all as the pallet issue
:D
   / Tire grooving with my chainsaw #44
Its a mystery!
Now that I think about it, I am glad I didn't do any videos. The tire grooving debate is practically an institution on TBN. Who would I be to put a stop to it? :)
Setting "science", "variables", "objectivity", and "proof" aside (who needs 'em anyway?), I think I'll be able to tell very easily if I have achieved any improvement. First, I plow sometimes for my neighbor. Even with a small amount of snow she has an area that I can't plow going up hill. If I can pull the blade while going up after grooving my tires, that'll be an improvement. Also, my usual plowing method, which is also the most fun, is to plow to the end of my drive, then turn around in the road and come back the other way. I am usually plowing in high range (reverse is too slow in medium) at full throtte. To make my U-turn, I crank the wheel and stomp the go pedal. The result is that the chains on my front tires bite while my rears spin and I do an awesome power slide. So, what I'm getting at is that I'm pretty familiar with the slippiness versus traction characteristics of this machine. I regularly experience a situation where better traction will be noticed.
As I said earlier, I'll keep y'all posted.
   / Tire grooving with my chainsaw #47
I knew a guy years ago that cut "W's" into R-4's and said it gave him greatly increased traction. He used a tire regrooving tool and I didn't pay much attention. In retrospect, I think he was onto something.
   / Tire grooving with my chainsaw #49
You are going to compare grooved/nongrooved while running chains on the front?? :)
The problem with this "testing" thing is when there's a failure, we don't know how serious the failure was. Did the tractor miss completing the task by just a "hair" or did it miss miserably??? Without knowing that we cannot decide if the grooving was a huge success or just marginal improvement.....
This may get much worse than the Pallet saga. :)
!! What happens to pallets in the snow? !!
Richard, I appreciate your skepticism. I believe I have responded to all of your skeptical posts very courteously and with good humor. I don't want this to be any exception.
I run chains on the front all winter on this tractor. Started doing it last year because the darned front tires wouldn't grip at all and I couldn't steer. Any comparison I make between grooved and non-grooved will include the front chains. They are not a variable, they are a constant
Furthermore, any compassion I make is purely anecdotal. I will by no means try to tell people grooving their tires will improve their traction. I will, however, relay my own experience with my grooved tires. You have relayed yours also, which I appreciate.
I am not trying to complete any "testing" for any purposes other than satisfying my own curiosity.
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
