New forks for my GC1705
   / New forks for my GC1705 #1
rider7767
Paris, TN
TYM T264 with loader and implements
I received my bucket forks today from Titan Attachments. They seemed very well built and will surely be enough for my little tractor. I will chain them for heavy stuff. IMG_20161228_134327.jpgIMG_20161228_134334.jpgIMG_20161228_134358.jpgIMG_20161228_134414.jpg
   / New forks for my GC1705 #2
I got forks like that on ebay, very strong. Lifted my backhoe off of my truck with no problem.
   / New forks for my GC1705 #3
I just bought the same ones, mine came with the stabilizer.. I mostly use them for lifting logs so that I can chainsaw them into firewood..
   / New forks for my GC1705 #4
I nearly went this route but I questioned the stability of the forks when attached to the bucket like so and the fact that u lose some lifting power. But I use mine with pallets and cutting firewood. Do you guys find that they don't move around on you. Im just wondering even though i went a different route.
They seem stable. I bought these to move small stuff around. I would not want to lift more than 500lbs in this setup. I don't want to bend my bucket. I have seen pictures where people have bent there buckets trying to use these like a forklift attachment.
   / New forks for my GC1705 #6
good point as i had forgotten about that as well.
   / New forks for my GC1705 #7
Mine don't move when I use a pipe to tighten them and use the stabilizer. I wouldn't try to lift anymore than 500lb's either, I'm not afraid of anything bending but I am afraid of snapping my front axle..
   / New forks for my GC1705 #8
I used mine to lift an old wood burning stove that must have weighted 700 lbs. It worked fine and the tractor had no problem lifting the load. I have added some bucket reinforcement so I'm not worried about bending anything.
I use the forks for so many things, sometimes they get more work than anything else.
I think mine will too. I have needed them many times before buying them. They are easy to take on and off.
That axle is very strong, but I stay on the safe side too.
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
2007 Ford F-150 Ext. Cab Pickup Truck (A55852)
2007 Ford F-150...
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
M&W PT407 4 Basket Hay Tedder (A56469)
M&W PT407 4 Basket...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A57024)
Kuhns AE10 Small...
2015 Ford Explorer (A56859)
2015 Ford Explorer...
