I am putting in a metal ceiling, where/how does the vapor barrier go?
   / I am putting in a metal ceiling, where/how does the vapor barrier go? #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
It is going in my 1,500 sq ft pole barn that has central heat/air via a gas pack. The metal will be attached to the bottom of the trusses. I will blow in cellulose insulation afterwards. I plan to use heavy/thick plastic, visqueen. I see two options but maybe there are other ways?
1) Simply lay the plastic on top of the trusses
2) Staple the plastic to the bottom of the trusses
3) Other ways/material/methods?
The problem I see with laying it on top is getting tight fitment against the angled upright portions of the trusses. Stapling it to the bottom will of course leave thousands of tiny holes (but maybe mostly sealed up enough?).
I only plan to run the heat or air about 8 or less hours a day, I may leave it at a moderate temperature overnight.
Not sure if this is important but I currently have an enclosed R11 insulated shop inside heated by a hydronic system and cooled by a window AC. It has a six foot ceiling, barn has a 10 foot ceiling. I have insulated garage doors on each end. I usually spend seven days a week out there.
John
I suppose I should take pics? Will post some within two hours,
   / I am putting in a metal ceiling, where/how does the vapor barrier go? #2
John - with your comments #1 & #2 - pictures would sure help. You are working on a shop built INSIDE a 1500 sq ft pole barn??
Above pic is the trusses facing west
Above pic is the North restroom/small office
Above pic is the Hydronic control system that heats the enclosed north and south areas
Above pic is the south enclosed area from the main part of the barn.
   / I am putting in a metal ceiling, where/how does the vapor barrier go? #4
I'd go the simple route and staple to the bottom of the trusses. Plastic is normally used for a vapor barrier, installed on the warm side. Since you plan on metal on the ceiling, that is also a nearly perfect vapor barrier, except for the seams, the plastic is sorta redundant.
Actually the insulated shop is complete, I am now hanging the ceiling in the main part of the barn. Pics have been attached, I use the area above the six foot tall shop for much needed storage.
So I could skip the plastic?
I might add that I have worked in an office my whole life, ever since my First Sergeant told me I was going to work in his office at 17 years old. If you see any flaws in my past designs/pictures it is because I did the best I could with the skills I had. I also live on a fixed income now so money has been a limiting factor at times.
In case you are wondering what I do out there:
Here is Grandmother, Daughter and Granddaughter
One of Grandmother's sons after a day of blind retrieves
The Daughter in the first pic
Another one of my pups I bred
   / I am putting in a metal ceiling, where/how does the vapor barrier go? #9
Regardless of the plastic location, I would be claustrophobic in a room with a 6 foot ceiling, but then I am almost 6 feet tall so maybe that isn't an issue for you.
I would say that the plastic is on the warm side just like the moisture barrier as applied to wall insulation.
   / I am putting in a metal ceiling, where/how does the vapor barrier go? #10
I wouldn't. Plastic should minimize condensation from forming on the steel on the cold side of your ceiling.
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
JLG ELECTRIC MANLIFT (A52472)
JLG ELECTRIC...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
