johneic
- Joined
- Jan 4, 2010
- Messages
- 228
- Location
- Paducah (West) Kentucky
- Tractor
- JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
It is going in my 1,500 sq ft pole barn that has central heat/air via a gas pack. The metal will be attached to the bottom of the trusses. I will blow in cellulose insulation afterwards. I plan to use heavy/thick plastic, visqueen. I see two options but maybe there are other ways?
1) Simply lay the plastic on top of the trusses
2) Staple the plastic to the bottom of the trusses
3) Other ways/material/methods?
The problem I see with laying it on top is getting tight fitment against the angled upright portions of the trusses. Stapling it to the bottom will of course leave thousands of tiny holes (but maybe mostly sealed up enough?).
I only plan to run the heat or air about 8 or less hours a day, I may leave it at a moderate temperature overnight.
Not sure if this is important but I currently have an enclosed R11 insulated shop inside heated by a hydronic system and cooled by a window AC. It has a six foot ceiling, barn has a 10 foot ceiling. I have insulated garage doors on each end. I usually spend seven days a week out there.
John
I suppose I should take pics? Will post some within two hours,
John
