Finished up the shed for the Tractor
   / Finished up the shed for the Tractor #11
I want to build a similar shed off my barn. Does the shed roof have same pitch as the barn?
No it does not and that is the reason it was limited to 20 foot wide. It would have tripled the cost to make it wider. So it will have to take the snow load of the snow falling off the barn but it is designed to hold our snow loads no problem.
   / Finished up the shed for the Tractor #13
1483138436997.jpg I want a shed on the right side. 12' high, so keeping 4/12 pitch really restricts my height for the shed. I could drop the shed floor lower than the barn floor since the hill slopes down.
I wanted to be able to drive under it all. I will see if I can find a picture of the Whole thing
Here is the view from a bit back. It does not have the same slope but it is enough and strong enough to handle the snow dropping off onto it as well.
The back of the barn. by tinstafl, on Flickr
   / Finished up the shed for the Tractor #16
Picture perfect...
It's a comfort to have a place for everything and everything in it's place!
Well Done.
It is great to get stuff out of the elements.
   / Finished up the shed for the Tractor #18
That's a nice addition to the main building. Just curious why you didn't go the full length of the main building?
TBS
There was too big a drop off and I did not want to bring in too much fill. I just leveled it out for the barn and the addition but siting it to fit my bus meant I needed more room on the side to pull in and back around to I had to push it towards a complex slope. also it is easier to go in and out of it with some extra space ad I can back the 15 foot batwing in easier.
   / Finished up the shed for the Tractor #20
I figured you had a reason...
What are the dimensions of the main building?
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2005 CATERPILLAR 267B SKID STEER (A52705)
2005 CATERPILLAR...
2015 FORD F-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD F-750 XL...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2016 CATERPILLAR 306E EXCAVATOR (A52705)
2016 CATERPILLAR...
2019 TerraGator 7300 Spinner truck (A55302)
2019 TerraGator...
