Peak torque ratings and associated rpm?
   / Peak torque ratings and associated rpm? #1
Mikkelsen
Member
Donnelly, Idaho
Kioti DK10
Why are manufacturers not listing peak torque ratings? What RPM does a Kioti DK5510 reach peak torque?
   / Peak torque ratings and associated rpm? #2
Kubota does,however the RPM in which it is reached is not listed.
   / Peak torque ratings and associated rpm? #4
Bore/Stroke: 3.43x4.03 inches [87 x 102 mm]
Power (gross): 55 hp [41.0 kW]
Fuel system: common rail direct injection
Rated RPM: 2600
Torque: 133.5 lb-ft [181.0 Nm]
Torque RPM: 1700
Also makes 43 HP at 1700 rpm.
Perfect, thanks Buick and Deere. Is that for the kubota? I imagine the Kioti would be similar?
   / Peak torque ratings and associated rpm? #9
   / Peak torque ratings and associated rpm? #10
You only need HP or Torque @ a known RPM to reverse calculate whatever (HP or lb/ft) is missing.
If you know an engine makes 25hp @ 2600rpm for example, than a simple calculation can be used to find this equates to 50.5 ft/lbs of torque.
Here's an online calculator...no math required. :thumbsup:
Horsepower & Torque Calculator | Spicer Parts
IMO when it comes to tractors, HP is typically used for power output ratings and high torque is obtained with gearing and hydraulics.
2003 Big Tex 10PI...
Service Truck (A59230)
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2020 Global R3 Air Street Sweeper (A56858)
2020 Global R3 Air...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
