Peak torque ratings and associated rpm?
   / Peak torque ratings and associated rpm? #1
Mikkelsen
Member
Donnelly, Idaho
Kioti DK10
Why are manufacturers not listing peak torque ratings? What RPM does a Kioti DK5510 reach peak torque?
   / Peak torque ratings and associated rpm? #2
Kubota does,however the RPM in which it is reached is not listed.
   / Peak torque ratings and associated rpm? #4
Bore/Stroke: 3.43x4.03 inches [87 x 102 mm]
Power (gross): 55 hp [41.0 kW]
Fuel system: common rail direct injection
Rated RPM: 2600
Torque: 133.5 lb-ft [181.0 Nm]
Torque RPM: 1700
Also makes 43 HP at 1700 rpm.
Perfect, thanks Buick and Deere. Is that for the kubota? I imagine the Kioti would be similar?
   / Peak torque ratings and associated rpm? #9
   / Peak torque ratings and associated rpm? #10
You only need HP or Torque @ a known RPM to reverse calculate whatever (HP or lb/ft) is missing.
If you know an engine makes 25hp @ 2600rpm for example, than a simple calculation can be used to find this equates to 50.5 ft/lbs of torque.
Here's an online calculator...no math required. :thumbsup:
Horsepower & Torque Calculator | Spicer Parts
IMO when it comes to tractors, HP is typically used for power output ratings and high torque is obtained with gearing and hydraulics.
40ft High Cube Shipping Container (A57453)
40ft High Cube...
Hatz Diesel 6 Inch Water Pump (A57453)
Hatz Diesel 6 Inch...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
Graco G4 Paint Sprayer (A56860)
Graco G4 Paint...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
