Changing fluid-filled tires - how to drain the stuff out?
   / Changing fluid-filled tires - how to drain the stuff out? #21
I don't think there is anything to patent:) It is just using the idea of having air in the tire to push the fluid out thru the small tubing..
Agreed, nothing to patent. I use the same method to drain water heaters to winterize the place. They would drain on their own, but it's a lot faster with air pressure. While that's draining I'll go open all of the valves 1 at a time. Since the lines are pressurized it'll blow most of the water out. Then I have a pressure tank with a water valve on it. Fill the tank with antifreezes and use a double female hose ( washing machine hose ) to hook that valve and another valve on the house together and blow antifreeze in the lines.
   / Changing fluid-filled tires - how to drain the stuff out? #22
Looks like a liquid/air separator will be too expensive. I may try the $10 vacuum pump that hooks up to an air compressor. Otherwise it may be the $5 squeeze bulb with tubing. Still a pain.....
   / Changing fluid-filled tires - how to drain the stuff out? #23
It doesn't have to be an elaborate separator. Something simple like this would work as long as you don't over fill the bucket. The biggest problem is something cheap like a 5 gallon bucket is likely to collapse under the vacuum pressure. IMG_8940.JPG
   / Changing fluid-filled tires - how to drain the stuff out? #24
That may work. Won't be pulling much vacuum. Thanks for the tip.
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
CHINESE 125 ATV (A54757)
CHINESE 125 ATV...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
