PatrickS2222
Gold Member
- Joined
- Feb 6, 2016
- Messages
- 494
- Location
- Brisbane, Australia
- Tractor
- MF35, MF135, MF203 with loader.
That seal is really quite easy to renew. Check the bearing preload while its apart - you might need to remove one thin shim to compensate for a little wear in the wheel bearing. Also, apply a thin film of sealant between each shim, and don't tighten those perimeter bolts super-tight - they don't seem to come loose, but, especially on early 35s (and previous models) with only six bolts, the occasional one fatigues and breaks.
If they all break ... the axle and wheel leaves the rest of the tractor.
