Household Well Water Pump Troubles
   / Household Well Water Pump Troubles #11
I'm also, wondering about the CSV changeover (PK1A PSIDE-KICK Kit – Cycle Stop Valves, Inc). Been reading and it sounds logical but changing out a lot of plumbing right now is not on the schedule. Already have some electrical, automotive, framing, roofing etc work around the house that is taking precedent. I would like to try the CSV on the outside well pump....also a jet pump but that one has a galvanized tank. It short cycles a bit too.
Tks
I can recommend the CSV, it works well on the well. :D
   / Household Well Water Pump Troubles #12
Cycle stop valves are great for systems with submersible pumps. Jet pumps can usually be set up with the pressure switch to keep the pump running at a desired pressure without cycling. Most jet pumps max out at 60 psi or so, so the CSV isn't needed.
   / Household Well Water Pump Troubles #13
After replacing a bladder tank I decided to see just what replacing a bladder would involve. To get the old one out it had to be cut in sections with tin snips through the hole. I've read to install a new bladder it must be twisted real tight and remain twisted some way to insert it.
As mentioned several times above, purchase a new tank and choose another time to be frugal.
   / Household Well Water Pump Troubles #14
I would think if the bladder was bad your pump would click on and off constantly.
   / Household Well Water Pump Troubles #15
It would as long as he was using water and it was less than could keep the pump running.
   / Household Well Water Pump Troubles #16
Easy to tell if your bladder is bad.
Shut off pump.
Drain water from tank. Note if any air escapes after water drains.
Check pressure in bladder. If pressurized - bladder is good. If not, bladder is bad.
Bad bladder - replace tank. Well X Trol is what I also recommend.
Good bladder - set bladder pressure to 2 psi lower than pump kick-on pressure.
If you still have problems, look elsewhere. Pressure switch, pump, foot valve, etc.
Hope this helps.
   / Household Well Water Pump Troubles #17
I would think even with the water off. When the pump reached pressure and cut off, it would drop and make the pump kick back on.
   / Household Well Water Pump Troubles #18
This can happen if the tank is totally void of air. Since you can't compress water, there is nothing to store pressure and the switch can hammer on and off. It happens very fast and is very hard on a motor.
   / Household Well Water Pump Troubles #19
When I replaced mine, I planned on using the old tank for air. I have my compressor in pumphouse with pressure tank and a line running underground to the shop. The big tank is sitting in the shop with air fitting on it. It allows the compressor to store up some compressed air. My plan is to eventually put it in the shop loft (out of the way) mounted in such a manner that I can drain any moisture from the main floor. I will also install a check valve in line to shop to take load off compressor.
   / Household Well Water Pump Troubles #20
Put in a new pump in the well Thursday. Get to take out tomorrow because I over tightened the fitting on the pump. Instructions for the new pump forgot to explain this. Goes on like a oil filter hand tight and one more turn. It runs but the back flow preventer is trapped and no water. Seems like the instructions would mention this. Trouble shooter for the factory says that is how he keeps his job.
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
2014 JCB 930 (A53317)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
2007 PETERBILT 335 LUBE TRUCK (A57192)
2007 PETERBILT 335...
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2007 Ford Taurus Sedan (A55853)
2007 Ford Taurus...
