fried1765
Super Star Member
- Joined
- Jan 6, 2015
- Messages
- 10,089
- Tractor
- Kubota L48 TLB, Ford 1920 FEL, 8N Ford, Gravely 12 HP "Professional", 48" SCAG Liberty
I do not have rear remotes, and even if I did, I might not spend the money for a hydraulic top link.
The "Hydraulink" may be just the ticket for me!
I need to be able to adjust the tilt/cutting angle of my 3pt. forks/rear blade/box blade/tiller/bush hog etc. from the tractor seat.
The "Hydraulink" seems like a reasonable solution, at a very reasonable cost.
It is available in both CAT l and CAT ll versions.
If you put "Hydraulink" in Google, you will see several U-Tube videos available.
There are reviews posted, on the Northern Tool website.
I just stumbled on the CAT ll version being CLOSED OUT at Agri Supply for $134.88, which is a super price.
A CAT ll model will work on a CAT l tractor. The only downside seems to be that the CAT ll model weighs 26 lbs., while the CAT l weighs in at 15 lbs. The CAT l at Northern is $249.99, and the CAT ll version is $299.99.
I will bush the 1" ends on the CAT ll down to 3/4" for CAT l.
The CAT ll is going to be best for me also, because I have the "Pats Easy Change" system, and it requires the greater top link length of the CAT ll model.
The "Hydraulink" has been around for a good while, and is apparently made in New Zealand.
I am away from my tractor for the Winter, but have ordered the "Hydraulink" from Agri Supply, and will try it out in the Spring.
