Poor man Hydraulic (almost) Top Link - "Hydraulink"
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #11
Thanks for the pic lesson Richard, I've been doing another way and you have to "click" on it to view it in a decent size.
yeah!
No problem Eric. You nailed it!!!
I really like your "double swivel" ends on your top link. Did you buy that or build it??
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #12
You know I'm cheap right?:laughing:
I wanted a "just right" stroke so I built it. I'll practice my big pic lesson.
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #13
I do believe that I can easily reach the "Hydraulink" adjusting valve without getting off my tractor.
75% of the time, not 100% of the time.
Sometimes you cannot reach the valve, which often orients itself down, which is a weakness in the design.
Sometimes load on the HydrauLink is such that you have to get off the tractor to put enough hand torque on the (downward oriented) valve to move it. Hand torque has always been enough on my Cat I HydrauLink. I have NEVER required a wrench.
Is the LOA for a Cat II HydrauLink the same as the LOA for a Cat I HydrauLink? It the Cat II HydrauLink is longer than the Cat I, you will not be able to use it with some of your Cat I implements.
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #14
Very nice work Eric!! Professional design and welds!!
The CAT ll Hydraulink LOA is greater than the CAT l, but I think that is an ADVANTAGE with my Pat's Easy Change.
I do not think the CAT l would be long enough with the Pat's, which lengthens the lift arms by about 4".
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #16
"In an ideal world" jeff9366 would have read my post accurately, and the jeff9366 scarcasm might have been avoided.
   / Poor man Hydraulic (almost) Top Link - "Hydraulink" #18
No sarcasm intended. I was attempting to be tactful.
Tactful would have been you going back to post #1 and rereading it, then posting a "sorry, I missed that :eek:" :D
John Deere X740 Mower (A50514)
John Deere X740...
IH 490 Disk (A50514)
2008 Genie S-65 65ft Telescoping Boom Lift (A50322)
2008 Genie S-65...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52748)
2020 Massey...
Kubota L2501D 25HP Utility Loader Tractor (A50322)
Kubota L2501D 25HP...
