Ridiculous! Thermostat help?
   / Ridiculous! Thermostat help? #21
What I got is 2.5. I think I need 2.75. The 2.5 is the size of the inlet. It barely slips down in the pipe, but it does. It won't sit on the lip for it.
If you can't get the right size you could cheat by cutting two pieces of tin to fit the 2.75 ". If you cut a hole into those two pieces of tin and sandwich the thermostat in there it would get you by.
   / Ridiculous! Thermostat help? #22
My first truck was an '85 F250 6.9 diesel. I used to block PART of the radiator with cardboard to help it warm up. But never the whole thing. I added some coolant without bleeding it. But I didn't think I needed to since it was only a gallon low.
On my 90 Cummins I have a winter front on the grill. I open the flaps at around 0 C. On my 98 I have a piece of cardboard covering the whole rad right in front of the intercooler. I pull the cardboard at around 0 C. Otherwise when it gets to -25 or 30 C you just can't get he cab to warm up.
   / Ridiculous! Thermostat help? #23
Go to autoparts and buy infrared thermometer pistol. They cost less than $30. Very usefull for many things around the farm. Good for checking fuses, breakers, bearings, bad electrical conection, insulation leaks, heating, radiator temperature and many other things. The cheap one have no emisivity correction so the temperature measured can be little off if the object is not black. When I need more precise measurement I spray a spot of black paint on the object or put on it a patch of black electrical tape.
Shop General Tools & Instruments The Heat Seeker 8:1 Professional Infrared Thermometer at Lowes.com
Performance Tool W89721 - Infrared Thermometer | O'Reilly Auto Parts
TIF Instruments TIF721 - Pocket IR Thermometer | O'Reilly Auto Parts
Yeah I had a 98.5 24 valve and it had a cover that had snaps around the entire grill. That helped some, but even without the cover I never noticed mine running low temp once it got there. Just took longer than normal to get there.
   / Ridiculous! Thermostat help? #25
Thermostat - Regular THM 191 | Buy Online - NAPA Auto Parts
It takes a little digging in the Parts Catalog (PC0244)to figure this out...
If thermostat is mounted vertically:
AA5749R (Range 160コ-178コ F)
Part Number: AF1710R
Replaces Part: AA5749R
Part Price: $214.55
Description: Thermostat
OR:
AA5750R (Range 180コ-195コ F
The part AA5750R is no longer available.
If thermostat is mounted horizontally:
Part Number: AR77411
Replaces Part: AF1522R
Part Price: $64.96
Description: Thermostat - THERMOSTAT, 195 DEGREES
Alternative Part
A-AR77411 Thermostat - THERMOSTAT 195 DEGREE - $67.95 (A&I)
Try a Gates stat for about $40 on eBay etc. the #33049 is 2.875" in diameter and is 190F.
There is a Stant that also fits. A #45479 or #13479 for the cheaper Stant.
If you prefer NAPA then a #357-180 or 33388 .
There, those are three sources of stats that will work.
FOUD IT ALL HERE:
Thermostat for 6 - John Deere
   / Ridiculous! Thermostat help? #26
I'm curious, but for what reason are you trying to get the temperature up in your 730 ? You mention "operating temperature" in the OP, but I don't see any real problem as long as the Deere starts and runs ok.
Or is it what you feel you need to just do it because you are chasing that coolant leak and are "there" ??
   / Ridiculous! Thermostat help? #27
At $200 each, the stock will likely stay high for some time ;-)
No, probably not priced right to sell to the budget minded restorer. But it is a relatively unique thermostat, may not be other options if originality of the tractor is desired. If not there will be alternatives to the industrious.
Isn't it bad on the motor to operate it if it's not up to correct temp?
   / Ridiculous! Thermostat help? #29
On older vehicles the reason would be efficiency. The spark plugs and automatic choke are designed for a certain temp range.
Have you tried simply walking into a parts store with what you have in hand? The OD of the thing can't be that odd that they wouldn't have something that would get you in the range. I bet a good auto parts store has 50-100 to choose from.
   / Ridiculous! Thermostat help? #30
Don't think it is "bad" nor will it damage anything. Just not as optimum as it could be. But your call and gut feeling.
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
2006 Mercedes-Benz Unimog 405 4x4 Flatbed Truck (A56858)
2006 Mercedes-Benz...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
