New (to me!) ford 3000, runs great, charging issue?
   / New (to me!) ford 3000, runs great, charging issue? #41
My first thoughts are that 14.3 volts is a little low but then you mentioned at 1000 rpm, It's probably higher at higher engine speeds. Personally I would like to see 14.5 to 14.7 but your close enough.
14.4 is a COMMON vreg setting. In any case, this is an old vibrating contact generator system. the charge voltage number is just an averaged total anyway. They don't charge well at low rpm as it is.
   / New (to me!) ford 3000, runs great, charging issue? #42
I was thinking 14.4 was pretty sporty. I've walked away from a bunch of those systems that weren't making that and they lived.
   / New (to me!) ford 3000, runs great, charging issue? #43
Agreed.. 14.4 is rockin on a mechanical vreg. 14.4 is a common alt voltage.
I have a couple that do 13.8 and still start year after year.
   / New (to me!) ford 3000, runs great, charging issue? #44
I'm just going by what my buddy who owns an electrical repair shop says he likes to see. My 90 cummins puts out 14.7 and about three times a winter I have to top up the battery with the charger. I have an F-935 that is the same. Because of that I like to see volts on the higher end, not lower.
   / New (to me!) ford 3000, runs great, charging issue? #45
I don't think anyone is arguing. I like to see 14+ too, and most alternator systems would be described as lacking at any lower voltage.. But it's not realistic or required from some generator / VR systems with 40 to 60 year old wiring. And a voltage reading is one measure of system function, not the only, or necessarily the most important.
   / New (to me!) ford 3000, runs great, charging issue? #46
Hey no problems. I learned something again.
CUSHMAN GOLFCART (A51406)
CUSHMAN GOLFCART...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
Large Metal Rooster Lawn Art (A51694)
Large Metal...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
