newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,187
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
Be sure to run some Cat 6, RG6 or fiber at the same time. Might as well have net.
Yep I went back through that with a bush hog lifting up so it's kind of half on top of the brush and lowering it down to shred it all. Then run through again with the bush hog all the way down to chop up what's left and make it a little easier to get through. Then I would dig the trench with either a walk behind tracked trencher, a backhoe or a ride-on trencher. I would not use a walk behind wheeled trencher as you will be cursing and very unhappy before you get 50 feet in.Yeah, that'll be fun.Run a bush hog through first, and use a riding trencher or a small backhoe, and you'll be glad you put that underground.
As I mentioned in in the first post, I can't clear or disturb trees/brush in this area at all due to wetlands restrictions, which was the main reason I was considering above ground conduit. I had to trench through similar land to run power to my pier, and it was a major struggle. But it's really the only option I have -- either trench with a walk behind unit and struggle, or not trench.
