How Do I Remove Aged/Dried Duct Tape?
   / How Do I Remove Aged/Dried Duct Tape? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
The PO of my tractor thought duct tape would be a good fuse panel cover,,, :confused2: NOT!!
Now, I need to try to figure out how to remove the tape.
The tape is pretty dried,,, GooGone did not touch it,,,
I have PB Blaster on it right now,,,
Any other ideas?
   / How Do I Remove Aged/Dried Duct Tape? #3
I just HATE when people use tape!
I might try varsol first before something aggressive like laquor thinner or acetone.
Or maybe a citrus based formula like goo gone. They are actually quite effective.
Yea, I did the GooGone,, 4 days worth,,
now 4 days of penetrating oil,,
I did "Google", no one seems to have a "magic bullet" for this stuff,,, :confused:
Stuff like acetone would probably destroy the decal?
   / How Do I Remove Aged/Dried Duct Tape? #7
I'd try mineral spirits, and get a plastic scraper. It allowed me to get off some very stubborn sticker residue a few weeks ago. Not sure if it will work on your duct tape though.
   / How Do I Remove Aged/Dried Duct Tape? #9
Lighter fluid (no fire!) is a little better or stronger than GooGone and not as harsh as acetone. Most of the time you will need to get it wet and then scrape it into the glue etc so the fluid soaks in.
I do have the plastic scraper,, I will have to find it!! :thumbsup:
   / How Do I Remove Aged/Dried Duct Tape? #11
Many of the milder things would work if you let it soak in. But it might also soak into the adhesive of your decal.
Another product is contact cement solvent or remover.
   / How Do I Remove Aged/Dried Duct Tape? #12
Agreed, zippo fluid is what a book collector I knew used. No damage to the dust jacket but stickers would come right off. I've been using for years since I saw him use it.
I got some lighter fluid,, I will try that,,, at least, it will remove the PB Blaster!! :laughing:
   / How Do I Remove Aged/Dried Duct Tape? #14
I have had real good luck with "Goof Off" and waterless hand cleaner like Gojo. soaking, soaking soaking.
I gotta say this looks like a tough one to tackle but you WILL get that crud off sooner or later.
   / How Do I Remove Aged/Dried Duct Tape? #15
I've used a product called Goof-Off to remove materials like duct tape... Ok, nothing is like Duct Tape, got it... but Goof Off has worked well for me on any kind of sticker/tape residue. I also recommend, as others have, using a plastic scraper. Takes a few soak-scrape cycles then wipe it all down with some Windex.
   / How Do I Remove Aged/Dried Duct Tape? #16
I've always used lacquer thinner, putty knife and a GOOD pair of rubber gloves. Lacquer thinner is carcinogenic - use with care. In your case - try a heat gun and putty knife.
   / How Do I Remove Aged/Dried Duct Tape? #17
There used to be a citrus product product named Desolvit that worked real well.It was in grocery stores, not sure if it is still available but it's the best I've ever seen and it will not harm that decal or paint etc.
This guy has the same duct tape issue,, but, it is on his roof!!
The duct tape is shown at 3:49 minutes.
I wonder what he uses?? :D
:laughing:
   / How Do I Remove Aged/Dried Duct Tape? #20
The PB Blaster should work similar but WD-40 is great for removing adhesives.
2020 DRAGON ESP...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
204158 (A57193)
204158 (A57193)
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
