TD90D
   / TD90D #1
DLTTrekkers
Paarl South Africa
Help needed
After I repaired the front part of the Gearbox.....I have no reverse. Before opening it again I would like some handsup what went wrong ?
   / TD90D #5
G'day a bit more info needed what did you repair at the front of the box and which transmission is in it
Jon
   / TD90D
Forward-reverse lever sits on your lefthand and comes thru the platform.
I replaced the seals and 1 taperlooking spacer
   / TD90D
Tomorrow its me and this tractor. Will report back on my findings . Lucky for me that my client have a lot of other tractors to use.
   / TD90D
   / TD90D
Lesson learned...never asume that parts was fitted correctly....always check manual for correct possision of parts !
DEUTZ MARATHON...
CATERPILLAR 926M 99" HANG-ON WHEEL LOADER FORKS (A60429)
CATERPILLAR 926M...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
(4) UNUSED FORERUNNER 12-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
UNUSED 250 GALLON FUEL TANK (A60432)
UNUSED 250 GALLON...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
