New Storage Tank - How to Protect My Fuel?
   / New Storage Tank - How to Protect My Fuel? #61
A large diesel generator is next on my to - get list. I'm the last house that ever seems to get power back here in the sticks....so also sort of a prepper move!
I recently acquired a Military Surplus generator I am getting ready for the next outage. Kind of frivolous for us since it was 30 years between week long outages but should be nice to have just in case. The MEP-803A is a tactical quiet model. They only go to 10KW rating for single phase use. The 804 up are 3phase only. I have load tested mine above the 10KW rating and it just plugged along. Here is my thread at the Steel Soldiers forum on the unit I bought.
These are auctioned off at various conditions and ages and can be a crap shoot but I rarely see where someone bought a unit they could not get going.
Came across your thread doing research on fuel storage for my purposes. I've only got a couple of 55 gallon drums and sounds like I will use a good bit more fuel than you do. Mine will be stored under a shed outside.
I concern myself a little with using metal at all but I see people have used metal storage tanks for eons. This warning in my JD manual states you should use plastic and NEVER use any galvanize metal.
DIESEL FUEL STORAGE
IMPORTANT: DO NOT USE GALVANIZED
CONTAINERS—diesel fuel stored in
galvanized containers reacts with zinc
coating in the container to form zinc
flakes. If fuel contains water, a zinc
gel will also form. The gel and flakes
will quickly plug fuel filters and
damage fuel injectors and fuel
pumps.
It is recommended that diesel fuel be stored ONLY in a
clean, approved POLYETHYLENE PLASTIC container
WITHOUT any metal screen or filter. This will help
prevent any accidental sparks from occurring. Store fuel
in an area that is well ventilated to prevent possible
igniting of fumes by an open flame or spark, this
includes any appliance with a pilot light.
I think I'll add a 90* fitting to the drain port on the tank and a ball valve.
What is recommended to use as a thread sealant and what material for the elbow and valve? I don't have an issue going stainless if that is preferred.
   / New Storage Tank - How to Protect My Fuel? #63
Personally I'm not that worried about sparks around diesel. Generally when I spill a few cups of diesel I grab my blowtorch to clean it up. It really only burns as long as you have the torch on the puddle. Occasionally some dirt or wood on the concrete will act as a wick to keep the puddle burning, but not much.
Gasoline is extremely flammable & dangerous igniting at the smallest provocation. Diesel needs a lot of persuasion to get started.
   / New Storage Tank - How to Protect My Fuel? #64
I would utilize a dessicant type breather on the vent on top of the tank, helps to rid incoming moisture in the air as fuel is used from tank.
Donaldson make them.
Already have a desiccant breather ready to go on. The problem is that all of the fill caps also have built in vents. Haven't been able to find one without a vent (which I understand why).
Any thoughts on this question? What type of thread sealant and what material for the elbow and valve? I'd rather spend extra money and not worry than go the cheap route....especially with this being the drain port.
   / New Storage Tank - How to Protect My Fuel? #67
brass, with teflon tape or liquid teflon for threads
Easy enough! I wasn't sure whether the Teflon would get eaten up by the fuel or not.
   / New Storage Tank - How to Protect My Fuel? #69
Use tape only if you're REALLY careful. Stray pieces could get into your fuel system. Using liquid teflon would be safer.
ALSO try to buy quality tape. Some cheaper offshore brands have been known to "ball up" and not seal properly.
Terry
   / New Storage Tank - How to Protect My Fuel? #70
Terry
I prefer the yellow stuff & liquid or paste Yellow means rated for gas. Yellow tape is twice as thick as the white stuff. I use a tube of yellow paste for all my air compressor or diesel plumbing fittings.
Loader Bucket (A50121)
2016 Big Tex 7'x16' Trailer (A50121)
2016 Big Tex...
40' CONTAINER (A51244)
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2001 John Deere 5205 (A50120)
2001 John Deere...
