BH92 on any M series Cab?
   / BH92 on any M series Cab? #41
And that answers my original question-- There is no M-series cab that can accept a backhoe, at least with factory mounting.
Maybe a second reading is in order, my friend. On page 5 of the attachment you'll see the M4022 Mounting Kit, which says it's "For M4011 with LA1153 Loader on M5040, M5140, M6040, M7040 Cab Tractors and with LA1154 Loader on M6060 and M7060 Cab Tractors..."
Has anyone actually spoken with someone with Kubota about all this yet?
Yeah, you're right, I was too quick to reach a conclusion.
   / BH92 on any M series Cab? #43
Kubota made a sub frame extension to fit the BH92 onto the ( Grand L Cab Version) versus the open station version of a L3560 that does not require the sub-frame extension kit. At least that's what they did to make it Fit my L 3560 .But the tractor then needs the bigger loader option to make it work, the LA 805 with (Power Beyond function) versus the smaller LA 555. Plus the Backhoe came with a Beefier sub-frame than the standard tractor and loader sub-frame.
Correct, and I like that sub-frame. I purchased a used L5740HSTC and that uses the extension ears. I had a tiny bit of interference and could not get the pins to line up and go through my older BH92, but that was solved with 2 minutes of careful grinding.
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
