1540 hydraulic filter
   / 1540 hydraulic filter #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
has anyone used the the wix number 51664 for the hydraulic filter ??? I read it on here somewhere that it would work ....thanks for the help bruce
thanks for the reply,,,,looks to me like it will work,,,,,,,,
   / 1540 hydraulic filter #7
As for the enthusiastic crowd remark, I didn't respond since I don't have a 1540. But I did some research and found my tractor uses the same filter as the 1540 so I measured mine to answer your question. Can't easily measure the diameter while it is on the tractor but if it were smaller it wouldn't seal. As for the length, it is the same as the MF dealer filter.
You are welcome. :)
   / 1540 hydraulic filter #8
it a lot shorter would not take a chance
   / 1540 hydraulic filter #9
Friends --- I'm soon due for my hydro fluid change and was beginning to secure filters. My MF1540 hydro has 2 hydro filters--one under the left rail and 1 under the right rail of different size. The diagrams show the filter under the right rail perpendicular to the tractor axis. The left one runs parallel to the tractor and smaller that the other in height. I'be looked at the AGCO online catalog but don't see the left one mentioned anywhere. Any insight you can offer?
Best,
brian
   / 1540 hydraulic filter #10
Years have passed and Heavens gates have opened. I have finally solved the mystery that nobody previously wanted to come forward and share with all mf1540 owners:
The elusive main hydraulic systems filter, is...
Wix 57403
There you have it. That痴 it...
Baldwin BT443 should also fit but it is rated 5 microns vs 12 for the Wix.
I致e got the Wix on and it works great.
Not sure why the silent secret from the pros on this forum not to pass on this information ...
Kubota L2800 (A47384)
2020 Bobcat E35I Mini Excavator (RIDE AND DRIVE) (A50774)
2020 Bobcat E35I...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
