Anyone have a LED dusk to dawn pole light?
   / Anyone have a LED dusk to dawn pole light? #11
Kiss that LED goodbye until technology improves. Get a big farmyard light and relax at night.
   / Anyone have a LED dusk to dawn pole light? #12
This is the one I bought:
Ledwholesalers 56 Watt LED Waterpoof Outdoor Security Floodlight 85-264 Volt Ac Warm White, 37�2ww - Flood Lighting - Amazon.com
It's not a dusk to dawn lamp (can be, but that's not what I wanted it for). It's mounted on an outbuilding and I use it when I need to get in there at night.
I have two of these mounted on the house:
Lithonia Lighting OFLR 9LN 12� P BZ LED Outdoor 3-Light Floodlight with Dusk to Dawn Photocell, Black Bronze - Flood Lighting - Amazon.com
They were installed in the summer of 2014 and still working great.
I've had cheap (<$50) LED lamps that didn't put out much light. I wouldn't go cheap again...get a good LED lamp.
One thing about LEDs is the color can differ quite a bit from one type to another. The first link I posted is a very bright white light. The 2nd link LEDs are bright, but bluish is color...they don't appear as bright and I think that's more due to the color then actual output.
   / Anyone have a LED dusk to dawn pole light? #14
I have one. It is a security light, not a work light. If I need more light I turn on the 4 1000w arena lights.
   / Anyone have a LED dusk to dawn pole light? #15
Yes, with LEDs, you need to check the color temperature. 3000-4500 Kelvin will be kind of yellowish. 6000 or 6500 Kelvin will be a bright white. As the color temperature goes up past that, the light becomes more "blueish"
Aaron Z
   / Anyone have a LED dusk to dawn pole light? #16
I traded out my sodium lamp, removed the extra hardware and installed a regular LED lamp on a simple photocell. I don't have or need very many watts, my LED flood lights turn on when they detect motion. I just want some light so I can see if anything is going on. I really like LED lights.
Same here... it is often very dark at the Washington property at night... no other lights visible...
The previous owner had installed a commercial Sodium Lamp that was overpowering... now use the fixture for a off the self LED bulb and couldn't be happier... also, no need to keep a special bulb around for a spare.
   / Anyone have a LED dusk to dawn pole light? #17
   / Anyone have a LED dusk to dawn pole light? #18
   / Anyone have a LED dusk to dawn pole light? #20
I intended to buy the SAMS light for my mother and father-in-laws places but was told by someone that although bright they only lit up a small area directly underneath them. Went to Lowes instead and got a more expensive LED light that was supposed to light an entire back yard. It does that and more. My mother especially is very happy with her light. It is located on a slight rise between her house and the stables and it lights up the entire back yard.
Anyway check the reviews and see what people are saying about the lights before you buy.
7033 (A51691)
7033 (A51691)
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
7046 (A50322)
7046 (A50322)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
