59 Ford 631 Spring at bottom of throttle lever...
   / 59 Ford 631 Spring at bottom of throttle lever... #1
dos0711
Member
Northeast,Florida
1959 Ford Workmaster 631
What is the purpose of the spring, washers and cotter pin that I've circled in red? Mine are missing and wonder if I should replace them.
   / 59 Ford 631 Spring at bottom of throttle lever... #2
It probably just keeps the linkage from "pivoting/flopping" around and much and keeps everything more snug with less play. Does the engine rpm seem pretty constant/governor work well?
Yes the governor works fine. The comp spring is in place and it holds a speed.
   / 59 Ford 631 Spring at bottom of throttle lever... #4
Maybe it reduces wear over the long term. I'd say that your machine has held up pretty well as is :)
Soundguy what are your thoughts...?
   / 59 Ford 631 Spring at bottom of throttle lever... #6
I always assumed that it was intended to keep the throttle shaft from riding up out of position. The spring would allow some axial movement which would prevent binding, as opposed to a cotter pin and washer.
   / 59 Ford 631 Spring at bottom of throttle lever... #7
agreed.. it's securing it in place and keeping it where it should be.
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
FUEL PUMP W/ NOZZLE (A53843)
FUEL PUMP W/...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
ALLISON TRANSMISSION (A53843)
ALLISON...
