Solar Recharge Trailer Break Backup Batt?
   / Solar Recharge Trailer Break Backup Batt? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Can anyone recommend a trailer break backup battery that has a solar panel maintainer built in? Or not recommended one?
   / Solar Recharge Trailer Break Backup Batt? #2
BatteryMinder is a great charge controller. Not integrated with a breakaway battery, but you'd just the it to the battery. Could easily just wire the charger to a female trailer plug. Just plug the trailer plug into the charger when you unplug from your tow vehicle.
   / Solar Recharge Trailer Break Backup Batt? #3
Do some re wiring , run a jumper from the running lights over to the battery , when you turn on your headlights or running lights you charge the battery
   / Solar Recharge Trailer Break Backup Batt? #4
If you have a 7 pin plug one is always hot (but you may need to add a fuse in the panel to make it hot). Besides, I think he's looking for something to keep the battery charged when the trailer isn't being used.
Some great ideas but yes looking for something to prevent drain while stored.
   / Solar Recharge Trailer Break Backup Batt? #8
It isn't complicated, plug it in with a cheap charger, or use cheap solar.
Don't plug it in, let it set for a year, it will be charged back up in 5 minutes when hooked to the truck. These are Barbie car batteries. KISS.
2011 Ford E-350 Cargo Van (A56858)
2011 Ford E-350...
2019 PETERBILT 579 (A58214)
2019 PETERBILT 579...
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2157 (A58376)
2157 (A58376)
406 (A52706)
406 (A52706)
CASE CX160 (A55272)
CASE CX160 (A55272)
