Crimp tool
   / Crimp tool #4
Use the crimp area of the standard crimp tool. They are usually located between the pivot point and the stripping area on standard wire stripper/crimping tools.
   / Crimp tool #5
The garbage stamped metal junk that comes with a lot of kits are probably the 2nd biggest reason that crimp connections have the completely undeserved bad reputation that they do.
This is what the junk looks like, do NOT get these!
That Klein tool above is an excellent choice.
This ratcheting kind is also excellent.
   / Crimp tool #6
For the splice terminals you want a wide flat pliers. The Klein pliers are a must- but not for those connectors. I have good luck with channel locks, lineman or slip jaw/combination. You insert the wires, squeeze the metal splicing bar into both wires and then close the cover.
Edit- OP- which connectors are you referencing? Half of the connectors would use the Klein crimp style pliers and the other half need a flat and wide jaw.
   / Crimp tool #7
   / Crimp tool #10
Hmmmm... I hate crimping because I never have confidence in them. I typically crimp the crap out of them and then cover it all up with heatshrink tubing.
I might have to invest in one of these 'Crimp specific pliers' and see whether my confidence improves.
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
