Crimp tool
   / Crimp tool #4
Use the crimp area of the standard crimp tool. They are usually located between the pivot point and the stripping area on standard wire stripper/crimping tools.
   / Crimp tool #5
The garbage stamped metal junk that comes with a lot of kits are probably the 2nd biggest reason that crimp connections have the completely undeserved bad reputation that they do.
This is what the junk looks like, do NOT get these!
That Klein tool above is an excellent choice.
This ratcheting kind is also excellent.
   / Crimp tool #6
For the splice terminals you want a wide flat pliers. The Klein pliers are a must- but not for those connectors. I have good luck with channel locks, lineman or slip jaw/combination. You insert the wires, squeeze the metal splicing bar into both wires and then close the cover.
Edit- OP- which connectors are you referencing? Half of the connectors would use the Klein crimp style pliers and the other half need a flat and wide jaw.
   / Crimp tool #7
   / Crimp tool #10
Hmmmm... I hate crimping because I never have confidence in them. I typically crimp the crap out of them and then cover it all up with heatshrink tubing.
I might have to invest in one of these 'Crimp specific pliers' and see whether my confidence improves.
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
