Crimp tool
   / Crimp tool #22
Is there a special crimping tool for this type of plastic insulated terminal? When I use the regular tool, they look like crap. 12 Pcs Quick Splice Insulated Wire Crimp Terminals & Male Spade Connectors Set | eBay
I use one like this. RS Pro - 4992313 - 1.5-6sq.mm wire size Ratchet crimp tool - Allied Electronics
You can spent as much as $300 but if you do a lot of em 40 or 50 bucks isn't that bad for a good ratchet style crimper. You want a ratchet style as it won't let go unless the terminal is fully crimped and a good connection is made.
Here's another D:cry:9 - DURATOOL - Crimp Tool, Ratchet | Newark element14
Actually this looks more like the one I have now.
   / Crimp tool #23
Does anyone have any experience with the Knipex Multicrimp?
I know Knipex is expensive in everything, but I must confess, I have purchased several of their pliers and found them to be excellent.
   / Crimp tool #24
Looks like a good one but likely expensive and awkward to use with that turret thing.
   / Crimp tool #26
The 'turret thing' is simply a place in which the various 'jaws' are kept. You slip the pliers over whichever jaws you want, push a button, and they are released into the pliers. You can then crimp whatever you wish, with specifically designed crimping jaws.
   / Crimp tool
I just crimped some with the same Channellock crimper I linked above and took a picture for you.
On the left using the non-insulated part, you can see the crimp well but as often happens when doing this the plastic is pierced.
On the right I used the insulated part, and yes the crimp is hard to see but it's solid and cannot be pulled off with reasonable force.
I think you broke the code there Ken. Good going with excellent follow through evidence. Gotta get me one of those so my nylon terminals don't look like crap.
   / Crimp tool
Here's another D159 - DURATOOL - Crimp Tool, Ratchet | Newark element14
Thanks Dick. This second one even shows a nylon terminal so I guess this tool does both.
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
UNUSED RAYTREE RMH680 HYD HAMMER (A54757)
UNUSED RAYTREE...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
