Crimp tool
   / Crimp tool #22
Is there a special crimping tool for this type of plastic insulated terminal? When I use the regular tool, they look like crap. 12 Pcs Quick Splice Insulated Wire Crimp Terminals & Male Spade Connectors Set | eBay
I use one like this. RS Pro - 4992313 - 1.5-6sq.mm wire size Ratchet crimp tool - Allied Electronics
You can spent as much as $300 but if you do a lot of em 40 or 50 bucks isn't that bad for a good ratchet style crimper. You want a ratchet style as it won't let go unless the terminal is fully crimped and a good connection is made.
Here's another D:cry:9 - DURATOOL - Crimp Tool, Ratchet | Newark element14
Actually this looks more like the one I have now.
   / Crimp tool #23
Does anyone have any experience with the Knipex Multicrimp?
I know Knipex is expensive in everything, but I must confess, I have purchased several of their pliers and found them to be excellent.
   / Crimp tool #24
Looks like a good one but likely expensive and awkward to use with that turret thing.
   / Crimp tool #26
The 'turret thing' is simply a place in which the various 'jaws' are kept. You slip the pliers over whichever jaws you want, push a button, and they are released into the pliers. You can then crimp whatever you wish, with specifically designed crimping jaws.
   / Crimp tool
I just crimped some with the same Channellock crimper I linked above and took a picture for you.
On the left using the non-insulated part, you can see the crimp well but as often happens when doing this the plastic is pierced.
On the right I used the insulated part, and yes the crimp is hard to see but it's solid and cannot be pulled off with reasonable force.
I think you broke the code there Ken. Good going with excellent follow through evidence. Gotta get me one of those so my nylon terminals don't look like crap.
   / Crimp tool
Here's another D159 - DURATOOL - Crimp Tool, Ratchet | Newark element14
Thanks Dick. This second one even shows a nylon terminal so I guess this tool does both.
UNUSED LANDHONOR LHR-G209 ANCHOR SHACKLES (A54757)
UNUSED LANDHONOR...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
