Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,651
We got 19" in the valley I live in, while surrounding areas got up to 30". The rear blade helps, but I'm seriously considering a front blade for my GC2600 (mainly because it would work in dirt too unlike a blower, and our 5-yr plan is a house with more property in another state). After helping clear out 2 other people's driveways where I had to scoop and dump (unable to push) I'm torn between the MF dozer blade (or adapting some other plow) or trying to make a light material bucket that's larger. I made one out of wood mainly to cut cleaning out the goat pen from 10-12 bucket loads down to 3-4. I've found it works well with the snow, but it's wood so I have to keep rebuilding it. Would love to find a larger bucket that would work with minimal modifications.
Tractor tire snow pusher lol, you can buy one or build one fairly easy, some use two tires that spread the snow like a V plow, others use a tractor tire cut in half and use that to push snow.
Something cheap and easy, I feel it won't be as good as a front blade.
   / Pictures of your snow weapons #3,652
Re: Pictures of your snow weapons, storm of 3-14-17
We got 36+ inches in about 12 hours. The local weather guy said it was coming down at a rate of 4" an hour a few times during the day. Went out twice to clear most of the white stuff. Even today I'm cleaning up some small snow to get ready for this weekends snow prediction.
Tony- Are you getting used to the V-plow on FEL? Pretty great, eh?
   / Pictures of your snow weapons #3,653
hmmmmm That's a thought. I do have 1 extra tractor tire sitting around unused. It wouldn't be much bigger than the existing bucket though. Looking into that now I remember seeing people use corrugated pipe as well.
http://www.tractorbynet.com/forums/snow-removal/257060-my-snow-pusher-build.html
   / Pictures of your snow weapons #3,654
well, all snow chains have been removed and stored, all snow equipment power washed and paint touch up done. Just got thru putting all equipment away for their summer vacation from winter.
had to make room for the spring arrivals
looks like ill have to get back to work installing some generators again....not sure if i want to wake up enough to do that.
   / Pictures of your snow weapons #3,655
Grsthegreat, how hard is it to remove and install the hydraulic power pack? Does it have quick disconnects so a portion of the hoses stays on the tractor?
I really like your blower setup.
   / Pictures of your snow weapons #3,656
its about an hour and a half ordeal. there are quick disconnects front and rear but i doint want to leave hoses on all summer. there are 2 large hoses run between blower and power pack and one electrical control. the time includes mounting the hydraulic pump and powerpack. once mounted it only takes a few minutes to swap between blower and plow or bucket.
it actually takes longer to mount chains than to mount the hydraulic system.
and they got a work out this season. i still have nearly 3 feet of snow on ground. but its now in the 40-50F temps so it wont last long now.
   / Pictures of your snow weapons #3,657
View attachment 502519 View attachment 502520
That's funny because we got another 5" of snow today. Of course it was followed by sleet and then rain so not much left.
   / Pictures of your snow weapons #3,658
The are in front of my equipment building (Front of House) was an old horse rink . I made it a bit bigger and graveled it. I plow it to keep equipment building open and get to chicken coop. The area down and around the house a was blast rock mountain at one point. I keep the back open to get at the horse staying in the "Cow Camp" and to get at the firewood. Of course, the wife wants the current horse paddock open also.
I probably plow an acre of snow.
Breezy Ridge GSMD - Home
http://www.tractorbynet.com/forums/projects/89163-busy-wife-weekend.html?highlight=
Just read through your project. You have a beautiful place there. From the hard work you put in, do you ever feel like you should have picked a different place to have your farm? Here is to many more years at your farm and I know there will be other spin off projects to come. Jon
   / Pictures of your snow weapons #3,659
Just a few things I's recommend to anyone thinking of this lifestyle.
You give up a lot.
You get a lot out of it.
If you can din't start from scratch like us, Take over an old place, if you must, tear down and rebuild, but at least the land is not raw.
Don't think of trying this if you are not in good heath and young feeling. I'd never be able to tackle this again. So if this is something your thinking about doing retiring, retire early! (I still have day job.)
   / Pictures of your snow weapons #3,660
Tactical Nuclear Snow Weapons
European Farmers sure do have the finest stuff.
Just big fast fancy utility tractors for instance.
T Series
250 Max. HP
CVT or 30R/30F
42 gpm Hydrauloc flow
Bare tractor weight wit Fluids 16,000 lbs
Less than 18' turning radius, better than many small cars!
21,356Lb Capacity Rear Hitch,
11,465Lb Capacity Rear Hitch.
With road gears the tractor could get a speeding ticket in every state but maybe Texas
Needs good tires,
Nokian TRI 2 Extreme Steel / Nokian Heavy Tyres
https://www.nokiantyres.com/static/.../assets/Nokian_Hakkapeliitta_TRI_Flyer_EN.pdf
Nokian TRI 2 / Nokian Heavy Tyres
New World Record for tractors / Nokian Tires
https://www.nokiantires.com/company...new-world-record-for-tractors-130-165-km-h-2/
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
*Selling at Royal Auction Tampa, FL Location* runs and drives. Needs jump. (A59228)
*Selling at Royal...
2018 John Deere TX (A53317)
2018 John Deere TX...
2020 dodge Charger Sedan (A59231)
2020 dodge Charger...
Stout Brush Grapple (A59814)
Stout Brush...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
