Depth of workbench, 24 or 36 inches
   / Depth of workbench, 24 or 36 inches #11
I find the most convenient arrangement is a wall bench 30" deep and a 4'x8' work table placed about 3' out from the bench. Ninety percent of the work is done on the table and the bench is used as a staging area to put tools, equipment Etc and thus not cluttering up the work top. The work table is fitted with a vice on one corner, plug strip on both long edges, and has access on all four sides.
Arrangement has worked very well for the last 46 years.
B. John
   / Depth of workbench, 24 or 36 inches #12
If you have the space, I would go with 36". You can always cut it shorter again, but you can't cut it longer. Though, a 30-32" work bench depth appear to be quite common.
Even if you don't use the full depth as work space, it can be used for other purposes. Small container storage, a tool rack, a row of miscellaneous spray cans, etc.
On edit: I see murhp replied while I was typing.
I inherited a 36" wide workbench (six feet long) and I use it exactly as you describe. Most of the active work area is the first 30 inches or so but I can keep some tools and supplies handy at the back (it has a backplate).
   / Depth of workbench, 24 or 36 inches #13
It depends on the main purpose of the work bench. If you are using it as a general purpose work bench 30-32" is fine. If you are using it as a wood working work bench I would recommend 24" for ease of clamping things.
   / Depth of workbench, 24 or 36 inches #14
All my built in work benches are 24" for the same reasons others have said. Height is very important too mine are 40-42". Depends on what work you do and your height though.
   / Depth of workbench, 24 or 36 inches #15
I've read several times that benches should be arranged so that your hands are working at elbow height.
Bruce
   / Depth of workbench, 24 or 36 inches #16
Yep 42 is elbow height so I use that mostly. Use 40 or even 38 if it is a bench where I might want to put some weight on the work.
   / Depth of workbench, 24 or 36 inches #17
Anything over 36" high works for me and for the depth I would make it 36". This works for pushing stuff to the back and still make room for working on the front.
We just bought a house and the bathroom vanities were 30" high. Who in the world would make them at that miserable height, midgets? The first thing I did was got new tops and extended the cabinets up a few inched. Make them for what is comfortable.
   / Depth of workbench, 24 or 36 inches #18
Your size matters, in this case. I'm 6'3, and build mine 40" tall and 36" deep. My stepsons can't reach the back wall....they are 5'8 - 5'10. Top 'em with a 36" solid core door blank. I built a 4x8' one as a walk-around back in my r/c model airplane days. It's now used as a shelf - welders under, storage on top.
   / Depth of workbench, 24 or 36 inches #19
Mine is 40" off the floor and 48" deep x 12' long. My 5 tool boxes are on it at the back wall and the hydro is under the front edge.
   / Depth of workbench, 24 or 36 inches #20
I made the wall-mount bench at my last house 40" deep, which was great to push stuff off to the back out of my way. But I could barely reach the peg-board at the rear for tools.
At my new place, I put a 16" deep bench along a 24' wall with pegboard behind it, which is a great bench for tools, toolboxes, etc. The opposite 24' wall has a 24" deep bench and is used for my miter saw and disc/drum sander. Then in the middle of the shop I built a 48"x96" freestanding table that I can walk around, which also serves as the outfeed table for my tablesaw. The table in the middle has been so much better than wall-mount benches in previous shops, and gives a lot of flexibility. I have built stuff as large as 5x10' barn doors on that table, and the ability to walk around it opens up a lot of flexibility. At some point I want to mount jack-up wheels on that table so I can move it out of the way as needed (tablesaw already has wheels like that).
2019 FREIGHTLINER CORONADO MIDROOF SLEEPER (A54607)
2019 FREIGHTLINER...
Galvanized steel fence (A53424)
Galvanized steel...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
