Mahindra 6000 Hydraulic suction strainer removal
   / Mahindra 6000 Hydraulic suction strainer removal #1
mnlisle
Somerville, TN
Mahindra 600
I'm changing the hydraulic fluid and I'm having trouble removing the suction strainer pipe. I've removed the retaining tab and I'm able to rotate the pipe but I can't pull it out. What could be preventing me from pulling it out? :confused::confused:
   / Mahindra 6000 Hydraulic suction strainer removal #2
Lots of spinach :laughing: Try a screw driver under the tab and carefully work it back and forth. There is probably rust between the tab and o-ring.:thumbsup:
You were right, the tab was rusted to the reservoir. Once the rust was broken, I was able to pull it out. Now I have to find some hydraulic fluid in VG-100 weight.
   / Mahindra 6000 Hydraulic suction strainer removal #4
Wow....what a mess, the hydraulic oil drained every where, based on the location of the stub pipe, I don't know how that can be managed? Anyone found a way? I guess a giant opening of a low profile container placed under the tractor? but once it goes through the floor it drips in all kinds of directions?:confused:
   / Mahindra 6000 Hydraulic suction strainer removal #5
I have three HST tractors that contain up to 10 gallons of fluid to drain. My largest is tall enough to use two 5 gallon pails. But lately I have been using two 5 gallon oil drainage pans, bought on sale at Advance Auto.. but avail lots of places. I put a large piece of cardboard down, then situate the two pans in a handy position and have at it... Works OK even with my shorter clearance tractors...
   / Mahindra 6000 Hydraulic suction strainer removal #6
I've had those for years; they are great, make it easy to dump into a waste drum, and if you are reusing the fluid after your repair, you can dump it right back in.
1997 Cat 953C Crawler Loader (RIDE AND DRIVE) (A50774)
1997 Cat 953C...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2014 Chevrolet Express 2500 Cargo Van (A50323)
2014 Chevrolet...
