New Kubota M7040SUHD or not!
   / New Kubota M7040SUHD or not! #41
Not a problem
   / New Kubota M7040SUHD or not! #42
Man that looks awesome i like the look with the loader dropped. Good to know that its pre wired for lights i will be sure to ask and see what they have.. my old man works with Hella and i can get some pretty powerful LED "samples" from him.
I decided to go with factory tires 9.5 x 24 the ones shown are a weird size off another unit.
Good call on the rear remote for the grapple that would do temporarily till i was able to get a kit installed.
So is there an update?
I was at this dealership today and there is a "sold" tag on the steering wheel. Still has the wrong 12.4-24 fronts on it and a new Kubota disc mower hitch on the back. Responded to your PM and didn't hear back.
   / New Kubota M7040SUHD or not! #43
mstockdale, I'm curious why you'd want those skinny 9" tires instead of the one's on it in the pics?
They have to order the stock tires in since they didn't have any for some reason when they put the tractor together. I stopped in also on Sunday and noticed they had a mower on it.
   / New Kubota M7040SUHD or not! #45
Thanks for the pic Stu. Next time you remove the FEL take us some pics of the process if you remember. Thanks!!!
Heres the pics of the process for attaching the hose connector back to the tractor.
   / New Kubota M7040SUHD or not! #46
See "yours" has the 24" front rubber as well. Most of them here were sold on the 20" Metric R1-W radials
Make sure you get rear work lights! The tractor is wired for them, they just don't come with it. You can get the factory kit (one per fender) or add your own LED in the existing holes on the fenders.
I didn't think of that until after the deal was made. Was only $100 to add a nice set though.
Don't have third function here, but if money is tight, run the grapple hoses to the rear remoteView attachment 504136View attachment 504137
That's a real good looking tractor!
   / New Kubota M7040SUHD or not! #48
Thank you very much Stu. I got it now. I had no idea that your FEL hoses are already "fastened" to a common block. I could not figure out how you could place each individual coupler, then move a handle to connect them. Great pics Stu. :thumbsup:
   / New Kubota M7040SUHD or not! #49
Thanks! Try to keep it clean. Mud & manure get their time on it!
The Metric Radials totally change the look of these tractors.
Where do I find photos? Can you post a few?
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
New Holland 479 Haybine (A50774)
New Holland 479...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
Assortment of Pipes (A50121)
Assortment of...
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
