sunnyside360
- Joined
 - Aug 8, 2006
- Messages
 - 1,561
- Location
 - Central PA
- Tractor
 - JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
Congrats on the new mower, sunnyside! I'm sure you'll enjoy it. You may need a plow on the front of that mower with all the snow you guys are getting up there. It's forecast be in the 20s here in the morn, but at least the white stuff is no where to be seen.
This will give you patience. I'd be itching to cut some grass. Thanks for the update. Be sure to report back after you've collected some grass under the deck.
Thankfully, I have an 8-1/2 foot snow plow on the front of the Kubota M110X cab tractor which can move lots of snow quickly. That's what I'll be doing later today when the snow stops dropping and drifting. I am anxious to get on the ZD1511-72 and mow some grass, especially on the steep side hill back of the house. The ZD1511 is heavier than the ZD331, and is supposed to have a lower center of gravity.
