2014+ Toyota Tundra 5.7.
   / 2014+ Toyota Tundra 5.7. #161
Cummings never had a good reputation for diesels, they were considered at the bottom of the list. CAT, Perkins, Mercedes, Detroit, others were preferred.
I can only speak from my experiences. I own a bulldozer, 1987 Case 850D with 6600 hours, the engine is a naturally aspirated Cummins, never been apart and no failures. The other is a 2001 Dodge 3500 reg cab 4x4, Cummins with a manual. Again, 300k miles and engine still going strong, never been apart. That's all I can speak to. Never owned a Cat, Perkins or Mercedes. I have worked on Detroits, noisy, oily beasts but do tend to have some longevitiy.
   / 2014+ Toyota Tundra 5.7. #162
The 5.7 never used timing belts.
I wont settle for anything but the 5.7.
Does my vehicle have a timing belt or timing chain?
But I agree with you when doing a timing belt, do the water pump.
Unless you are buying dollar store transmission fluid, 20,000 miles is a waste. I do mine every 2 years, which is 50,000 miles with full synthetic. I think i would pay the extra for Toyota atf.
You are right about the timing belt cuz the 5.7 uses chain. I must have been thinking about my lady's Acura that I just replaced. :)
The reason I do it every 20K is because each time I drain and fill I only replace 1/3 of the total fluid. I use Toyota fluid and it costs around $55 bucks which is cheap for 20K miles.
   / 2014+ Toyota Tundra 5.7. #163
Can't speak about 2014 model year - but I love my Tundra. It's a 2010 - 5.7 - 4 x 4. Appx. 65,000 miles and I've had it since new. Just went across scales at gravel pit this morning and registered 18,000 total lbs. Breakdown as follows: Dump Trailer -( Belmont 6'8" x 12'- 12,000#GVW) empty wt with wood sides - 4000# appx.---Passenger, tools, etc - 400# appx----Truck, curb wt. - 5600# appx.---4 yds. 1-1/2" crushed stone in trailer - 8000# appx. Pulled it OK - but I definitely knew it was back there. Also - gravel pit is only 5 miles from my house. Scales were busy with trucks coming out so I couldn't get weight before loading. Will try next time to get weighed empty to see weight of gravel or stone I'm hauling.
   / 2014+ Toyota Tundra 5.7. #164
How do they charge you for the gravel if they didn't get a empty weight?
   / 2014+ Toyota Tundra 5.7. #166
Yes - they do charge per yard for smaller quantities. They have a small articulated Kubota loader with a 1 yard bucket.
   / 2014+ Toyota Tundra 5.7. #167
Lot's of places charge by the scoop.
   / 2014+ Toyota Tundra 5.7. #168
I have bought at 10 or so places and its always by weight except for mulch and such.
Guess its a regional difference.
   / 2014+ Toyota Tundra 5.7. #169
I have a 2003 Tundra TRD 4x4 w/4.7L. Love it, and only ~53K miles.
Lately I've been looking at the 5.7's....
I have a 2015 double cab with the TRD package, 5.7 engine. I only have about 8500 miles on it. So far, I am very satisfied. It is tremendously more powerful than my 2004 with the 4.7.
   / 2014+ Toyota Tundra 5.7. #170
When I liven in northern New England, where that post was from, I bought small amounts of gravel by the scoop. Big trucks full were by the yard and never by weight. Probably because small operators, which was everyone, didn't have scales.
When I got to Ohio, everything was by weight and I had no way to compare how much to order. All this probably because most New England gravel is "bank run" and most Midwest is crushed rock.
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
2024 JOHN DEERE 3039R LOT NUMBER 58 (A53084)
2024 JOHN DEERE...
