GC2300 Directional Light Operation
   / GC2300 Directional Light Operation #1
dnw64
SE Vermont, South Jersey
Kubota B3030 Cab
When I turn the Left turn signal on, it blinks, and the Right one comes on steady.
When I turn the Right turn signal on, it blinks, and the Left one comes on steady.
Is this normal operation, or do I have a wiring problem?
   / GC2300 Directional Light Operation #2
My GC1720 does the same so either it's normal or we both have a wiring problem.:laughing:
Ok, thanks.
That's what I suspected, but figured that if it needed to be fixed, the time to do it was when I was doing other wiring stuff.
   / GC2300 Directional Light Operation #4
My New Hollands do the same.
   / GC2300 Directional Light Operation #5
My experience with old cars would have me look for a ground problem. I don't know the theory but have always managed to fix the stuff myself.
That was my suspicion. The fact that both sides worked the same made it seem less likely but thought I should check anyways.
Speaking of bad grounds, I had 2001 Mercedes that had a "bulb out" detection system that was often fooled by a weak ground in the bulb/socket connection. Even though the bulb worked perfectly fine, it still gave an error message.
   / GC2300 Directional Light Operation #8
There is nothing wrong with the ground on your directional lights. They are working as designed.
   / GC2300 Directional Light Operation #9
Yep, what arizona said. They're operating normally.
(5) Dura Trench Drain Grates (A56469)
(5) Dura Trench...
UNUSED RAYTREE RMLL60 60" HYD POWER RAKE (A57193)
UNUSED RAYTREE...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2013 Ford F-150 Crew Cab 4x4 Pick-up Truck (A55852)
2013 Ford F-150...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A57024)
2-Row Peanut...
