Converting Land Pride Tiller to Slip Clutch From Shear Bolt
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #1
buckslayer5676
Kubota
I'm looking to possibly purchase a used Land Pride RTA1550 tiller and I believe it is currently set up with a shear pin. I'm in rocky soil so I'd like to convert it to a slip clutch. To do this, would I simply need to purchase a new PTO shaft with a slip clutch?
Thanks!
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #2
Thanks!
convert from shear pin to slip clutch on my rotary cutter PTO ...
TractorByNet.com – Compact Tractor Reviews, News, Prices | Compact tractor forums, news, reviews, information. Forum General Forums Attachments
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #3
I prefer the shear bolt. Thats what i have on my 4ft woods brushbull . Takes around 15 minutes to install new one. I carry extra bolts and tools on the tractor. I use grade 5 bolts. To me shear bolts are better as i don't use my cutter that often....so no need to worry about adjusting the clutch. If that clutch is froze up and you don't know it...well you have bigger problems now !
Good point...maybe a shear bolt would be OK. I've just always heard that a slip clutch is the way to go for a tiller.
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #5
The slip clutch is better on a Roto-tiller for my uses.I have lots of rocks also;leave the discharge shute wide open.
It takes about 15 minutes or so to service the clutch every spring,not a big deal.I have two bush-hogs,one with a clutch and one with a shear pin;so familiar with both.I have only sheared a couple of bolts on my BH and it's an easy change out;I would think on a tiller it would happen more often and be a pain.
Thanks for the feedback! Yes, I agree...I'm going to stick with a slip clutch...
To convert one though to slip clutch, would it merely be just buying a new aftermarket $175 PTO shaft with the slip clutch? I believe the Land Pride PTO shafts are outrageously priced if I'm not mistaken.
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #7
My manuals are buried in a storage due to moving; but,I believe the slip clutch is a separate assembly from the shaft. Just add it on. Changes the length also.
Here in the NW with the dampness the slip clutches are a real pain in the rear due to swelling and corrosion seizing them up. I vote for shear pins for simplicity.
Ron
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #8
My tiller has a slip clutch and like a dope I did not adjust it the first time I used it and hit some roots and it did not slip, hopefully It dident cause any damage. So I adjusted the clutch and it's kind of a pain in the butt, doesn't take that long but trying to guess what tightness is right is a guessing game depending on your soil condition. I see why the shear bolts are a no brainer.
Op, before you spend your money on a slip clutch, why don't you try the tiller with the shear bolts and see how it works out for you, if the shear bolts are a pain then buy the slip clutch and you will have something to compare it to. I find trying something first gives me a frame of reference to judge the second option by.
   / Converting Land Pride Tiller to Slip Clutch From Shear Bolt #9
I concur. Just took me half an hour 45 minutes or so to service my King Kutter tiller clutch this week. Remove a plate to get to the clutch. Loosen up all the bolts. Jam a 2x4 into the tines the fire it up & engage the PTO. Nice bang & the clutch popped free. Cut into the 2x4 an inch or so. Then had to tighten it all back up (2.5 turns after the bolt touches each spring).
I was pissed when I found out my old rotary cutter had a sheer bolt instead of the clutch as my dealer told me before I knew better. But in 3 years I spent 0 minutes dealing with maintenance outside of greasing. At least 4 hours of maintenance in 3 years on my tiller just because of the clutch.
I wouldn't mess with a PTO clutch unless you are in conditions that would break sheer bolts a lot. I never broke any on my rotary cutter even mowing yucca that wbog my machine nearly to the point of stalling. Very fiberous & nasty but to would take it a few seconds to slow it down rather than instantly, which would have broken sheer bolts.
15200 (A56857)
15200 (A56857)
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A60460)
2015 Kenworth T880...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
