M60 Tank Can't Keep Battery Charged
   / M60 Tank Can't Keep Battery Charged #1
4tillingdirt
nc
N/A
I have an M60 Tank with the 23 HP Kawasaki engine. It has a little over 500 hrs and the clutch started not wanting to engage so I adjusted the 3 screws on the clutch so it engages most of the time - sometimes have to rev engine. Problem is I just put a new battery in and either the clutch is draining the battery or it isn't charging properly. I have a multi-meter so I guess I need to start checking and see how much voltage it is putting out when running?
   / M60 Tank Can't Keep Battery Charged #2
Serious, you have one of these?!?
   / M60 Tank Can't Keep Battery Charged #3
One of those, with 23hp, would be overworked a bit on the hills.
Bruce
   / M60 Tank Can't Keep Battery Charged #4
An M60 ... how cool is that?!?!?!
   / M60 Tank Can't Keep Battery Charged #7
Lets not scare him away while we are having fun.
Probably one of these.
Bruce
Bummer, but that still looks cool.
OP: Check the voltage at the battery when the engine is running. It should be about 14vdc. If not then check back up the charging circuit.
-R
Yep reading 14.3 volts. I am going to adjust on the clutch. I think the gap is too large because when I mowed the other day it would crank but I could tell the battery was weak. After I finished mowing it wouldn't start.
do you measure in the slots that are directly above the bolts - .015?
   / M60 Tank Can't Keep Battery Charged #10
What is the battery voltage with the PTO engaged?
Sounds like you might have some shorted turns in the clutch causing high current usage.
Richard
2011 FORD F-650 SUPER DUTY (A48992)
2011 FORD F-650...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
2013 CASE 580N BACKHOE (A50458)
2013 CASE 580N...
More info coming soon! (A49346)
More info coming...
2019 Ford E-350 Super Duty Knapheide Enclosed Service Van (A48081)
2019 Ford E-350...
New/Unused 2 Post Car Lift (A48837)
New/Unused 2 Post...
