M60 Tank Can't Keep Battery Charged
   / M60 Tank Can't Keep Battery Charged #1
4tillingdirt
nc
N/A
I have an M60 Tank with the 23 HP Kawasaki engine. It has a little over 500 hrs and the clutch started not wanting to engage so I adjusted the 3 screws on the clutch so it engages most of the time - sometimes have to rev engine. Problem is I just put a new battery in and either the clutch is draining the battery or it isn't charging properly. I have a multi-meter so I guess I need to start checking and see how much voltage it is putting out when running?
   / M60 Tank Can't Keep Battery Charged #2
Serious, you have one of these?!?
   / M60 Tank Can't Keep Battery Charged #3
One of those, with 23hp, would be overworked a bit on the hills.
Bruce
   / M60 Tank Can't Keep Battery Charged #4
An M60 ... how cool is that?!?!?!
   / M60 Tank Can't Keep Battery Charged #7
Lets not scare him away while we are having fun.
Probably one of these.
Bruce
Bummer, but that still looks cool.
OP: Check the voltage at the battery when the engine is running. It should be about 14vdc. If not then check back up the charging circuit.
-R
Yep reading 14.3 volts. I am going to adjust on the clutch. I think the gap is too large because when I mowed the other day it would crank but I could tell the battery was weak. After I finished mowing it wouldn't start.
do you measure in the slots that are directly above the bolts - .015?
   / M60 Tank Can't Keep Battery Charged #10
What is the battery voltage with the PTO engaged?
Sounds like you might have some shorted turns in the clutch causing high current usage.
Richard
I haven't checked it with the PTO engaged. I did adjust the clutch because the gap was way off. I am going to mow the yard in the next day or two and see how it does. Hopefully that is all it needed.
   / M60 Tank Can't Keep Battery Charged #12
Sounds like Richard might be onto something.... the PTO clutch gap should have nothing to do with charging. Some shorted windings in the clutch would for sure. The charging circuits in small engines are often pretty anemic, so any excess current draw will REALLY affect charging. That's why I wired a switch in the headlight circuit on my Cub. My wife really doesn't need headlights mandated by the safety police when she is mowing in broad daylight.
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2018 Kubota U17 (A53317)
2018 Kubota U17...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
